Question about Sony PlayStation 2 (PS2) Console
Reset cable came deattacted where does the ribbon attach to the bottom
Of the console
I have a ps2 but you cant watch rated r moveise it needs a code to un block it and i dont know it how can i get a unaversill code for it
Posted on May 14, 2008
I need schematic diagram for sony playstation 2
there is a ribbon wire that attatches to the reset button and to the console it is still attached to the reset button where dose it connect to on the console
May 23, 2010 | Sony PlayStation® 2 Console
My nintendo ds top screen is white
it might be that the ribbon cable connecting the top screen with the bottom screen is loose. you can open it and fix it by yourself, if you want. if it doesn't fix the problem, is either the screen or the ribbon cable that needs replacement.
Jan 05, 2010 | Nintendo DS Console
Bottom screen completly blank top screen is fine ,
Screen cable has come disconnected from housing or fatigue has worn out cable ribbon between top and bottom.
If you take apart to investigate make a scketch of DS and where you took screws from etc.
putting back should be reverse of removal.
Watch out for hidden clips in plastic housing etc.
Ribbons are available from ebay.
AndystUK
Aug 30, 2009 | Nintendo DS Lite Console
Faulty game console
Maybe the ribbon cable was damaged. the ribbon cable is a flat wire thing used to connect the top screen and bottom screen. you can buy a ribbon cable on ebay for a cheap price.
if that wasn't the problem, maybe the bottom lcd screen is dead. you'll need to replace that.
Dec 26, 2008 | Nintendo DS Lite Console
Broken nds ribbon cable
Yes, this can be fixed. You will need to replace the top LCD screen of the NDS, as the cable attaches directly to it. The speakers will need to be soldered to the new top LCD screen, as the top replacement screens usually do not come with speakers attached to it.
Dec 22, 2008 | Nintendo DS Lite Console
Playstation..2
Hi Sammy,
You have a connection problem in the Reset Eject circuit.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Nintendo ds damaged ribbon cable
You can't buy a ribbon for the bottom screen. (You can buy the ribbon that connects the motherboard to the daughter board which connects the top screen.). A new screen is the answer but be very careful when taking off the touch screen. Gently pry the two screens apart or else you will need a new touch screen. Also make a note of how the touch screen is attached to the LCD screen, as the touch screen is not the same size as the LCD screen. How have you damaged the ribbon? Could it be that it may not be pushed tight and straight into the connector? BTW the top and bottom LCD screens are the same. Some unscrupulous dealers have been charging differing amounts for 'Top' or 'Bottom' screens!
Oct 27, 2007 | Nintendo DS Console
Nintendo DS bottom display screen
Hi I have a problem with my bottom screen as well. I was replacing the case as the hinge was broken. When i was putting it back together i noticed a slight tear in the ribbon cable which is attached to the board and the bottom screen.
When I turned it on I found I had poor colour and contrast in the bottom screen however the top screen was fine.
Where this ribbon cable is attached to the board there is two small cables attached to the board beneath it, maybe one of these has come away and needs repositioning or your bottom screen needs replacing.Try this site for diy tipshttp://site.powergamingparts.com
Cheers Chris
Oct 24, 2007 | Nintendo DS Console
PS2 Power Ribbon
you need to replaced the ribbon cable
go to www.repairmyvideogame.com
they have the parts for $1.00
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
