Question about Vacuums
The bristles aren't turning so aren't picking up any fur or hair
    President:
  • 1,673 Answers
Don't know what you have, but check the belt and brush roll. Either the belt broke or is stretched to the point where it won't turn the brush roll.
Posted on May 13, 2008
When should I replace my vacuum roller brush? How long should the bristles be to properly pick up debris? It doesn't seem to pick up on our tile floor any more. (NSS-Pacer-115UE)
If the vacuum is weak, it may not be the brush. Bag and filters need to be clean and empty. No obstruction in the vacuum system. Motor running at full speed. etc etc.
Jan 01, 2018 | Vacuums
The brush motor seems to be jammed with hair, I can't figure out how to clean it out. Can it be disassembled and cleaned?
depends onn make and model of vacuum. Most brushes are belt driven and not linked to a motor. For hair around the brush bristles carefully cut along the length of the brush roller taking care not to cut any of the bristles, then pull them off. Some makes have a releasable base to make this easier, these have several large plastic screws that turn with a coin. Hope this helps
Aug 03, 2016 | Vacuums
Already replaced filters. Suction is fine. Only have short nap rugs. Is not picking up hair, thread small things on the carpets. I have cleaned the bristles on bottom as well.
Turn the vacuum over with the bristles up. Turn on the vacuum and see if the bristles are turning. If not, then replace the belt that makes the bristles spin.
Mar 05, 2016 | Vacuums
What's the best vacuum for pet hair?
Try a bagless vacuum cleaner as hair blocks up bags very quickly. One that is around 2000 watts should have enough power to do the job. As for the price check appliance stores for sales and deals.
May 31, 2013 | Vacuums
My Bissell BS3920F upright (similar to the 10N6F) has been working wonderfully for the past 3 years but suddenly seems to not pick up dog hair as well as it used to. It has been pulled apart by my husband...
Check to see if your brush is not worn down, they do wear with age - compare the length of the bristles with a new one. Replace the brush ir there is a significant difference in bristle lengths. Also check the flexible bend where the pick-up head joins onto the upright section for blockages and fluff.
Feb 24, 2011 | Bissell Vacuums
Belt not turning, smells hot, I cleaned brushes and everything.
Check to see that the belt has not slipped off of the bristle bar. If it smells hot that typically comes from the smell the belt makes if it is slipping. It will slip if it is not able to turn the bristle bar. Disassemble the bristle bar from the chassis and check the ends of it too see if they spin freely. It's typical that the ends get tied up with carpet threads and hair. Remove that mess, and then use some lubricant like silicone or Crisco cooking oil on the dowel of each end that is holding the bracket you had to unsnap from the chassis to remove the bristle bar.
Nov 02, 2010 | Dirt Devil M088920 Upright Vacuum
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
