Question about Brother MFC-7820N Printer
OK almost a months ago on the screem shows the ; Back cover open- Close the back cover I couldn't find the back cover which is open what is that mean can you please tell me which is the back cover that I never touch before, Thanks a lot for your kindness. Linda
This happens to mine when it is actually paper jam in the back. Open the back cover, then open the black guard behind that then depress the two purple levers and pull out the sheet. Two people make it easier but I can do it myself.
Posted on Sep 08, 2010
Lost back cover sharp part ccabbb693we01 (model lc40le820 or 810
Hi - I also lost same back cover(ccabbb693we01) during cleanup. Let me know or I will let you know if we find it. I just ordered one on special order,but they cannot assure me to get it.
Not long ago,I ordered at two different place on special order but I was told after close two months (part not availlable).
Today,poor service is not surprising from manufactures when finding parts.Waiting two months to know if is is availlable is ridiculous
dtelectronic47@gmail.com
Domenico Toto
Mar 08, 2014 | Sharp LC40LE810 40 in LCD TV
When I change the toner, the LCD shows "back cover is open, please close the back cover" where is the back cover?
The back cover is located on the back of the printer at the bottom. You can find it by looking for two tabs on the right and left that if pushed will allow you to open a paper guide that has two white wheels on it. Open this guide and then close it again so that the system understands that it is closed. That should solve your problem.
Sep 08, 2010 | Brother MFC 7420 All-In-One Laser Printer
Just bought MX870 and put power on and it says "The feeder cover is ope Close cover and press ok." I closed every cover and pressed ok but still shows that error.
The two covers on top are just not aligned properly. Open both top covers (one opens to the right one to the left). Close the cover that opens toward the right 1st (you should hear it click into place) then close the second cover. Press "ok" should be good to go.
Sep 01, 2010 | Office Equipment & Supplies
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
I have an 1100 watt Aurora. It has power the display lights up but it doesn't heat up. It was purchased from Home Depot about 5 months ago
Five months ago ... it may still be in warranty. If so .. take it back ... dont open it up ... you will jeopardze your warranty standing.
Do you ever open the door while the machine is running? If you do ... the door satery interlock switches may have failed. If there is no warranty issue, you may want to remove the cabinet and check these little switches.
What happens is this ... when you close the door, the switches report to the oven that the door is closed and it is OK to turn on the heat. If the switches are burned, the contacts don't close and the oven thinks the door is open and will not turn on the heat.
Thanks for your interest in FixYa.com
Jul 08, 2010 | Microwave Ovens
I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
follow this:
Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
Make sure that the document cover is closed, and then open the scanner unit.
Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
put it back in the printer.
Close the scanner unit, then press the OK button.
then print a nozzle check
Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
Brother MFC-7420 Fax Scan Copy
Maybe there is broken at the back cover try to check again the back cover,inspect the cover very well .
Nov 09, 2008 | Office Equipment & Supplies
My HP deskjet F380 is showing E
Try this :-
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
Brother MFC-7820N Printer Logo
545 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
