Question about Fisher and Paykel DEGX1 Electric Dryer
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer and louder screeches on revolution. Sometimes stops all together but only for a brief nano second. Any clues??.
  • Fisher and P... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
My 2006 VW Jetta is making loud, screaming/screeching, sound from the passenger side-front, behind the the dash/glove box, between the engine and wheel.
I would like to think it is the electric fan behind the radiator that is screeching. When you stop the car, everything should stop, but that fan. That fan is supposed to cool the radiator, even after the engine is off and the car stops. It would not be so bad, because it does not run as much, in cold weather, but in hot weather, it should start sooner and run longer.
I needs to be replaced.
Be blessed.
Feb 25, 2014 | Cars & Trucks
My Frigidaire dryer FEQB4000FSO stops running and the lights blink after just a few minutes. What could be the problem?
Your dryer inside of it. The drum turns on two wheels and the drun its self has a belt around it the wheels are on each side of the drum on the bottom and have bearings in them that fail letting the drum ride on metal to metal making a scrubbing or dragging metal sound. This is what your problem is it is not an expensive fix but just make sure this is all you are charged for. Please rate my solution and leave testimonial this is how i earn my achievements Thanks in advance
Apr 22, 2012 | Frigidaire Dryers
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screeching noise until dryer heats up. After the dryer has run for about 5 minutes, the screeching stops.
Sounds like you have a dryer drum belt that's getting bad. Once the belt gets warm enough, it becomes more soft and pliable, lessening the noise. Needs to be replaced. Hope this helped!
Nov 08, 2009 | Dryers
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
My RCA is screeching
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
The Dryer is not Squealing- It is SCREECHING FOR THE ENTIRE CYCLE...
could be rollor wheels that support rear of drum need grease or replaceing also have a slide bearing in frount may need lub or replaced
Nov 03, 2007 | Whirlpool LEB6300 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
757 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
