Question about Samsung SyncMaster 793DF 17" CRT Monitor
I have a samsung monitor SyncMaster93DF it stopped completly with a little sound (tick tick ) i oppened it and found the hot transistor shorted (st2310) i replaced it with bu2527 because i couldnt find the original onre in the market, the monitor started but with no high voltage and the monitor repats start and the relay sound goes on and off , the power suplly voltages are all good and gets very hot but dosent fail\r\ni checked all the parts diodes and transistors around the flyback transformer but they are all good also parts of the power suply all good i am very confused about these problem if any one can helo it would be highly appresiated and thanks in advance,
    Problem Solver:
  • 14 Answers
Try C5804 or J6812 instead of bu2527..replace IRF630 in 50 volt supply line.it may b faulty...bt if problem after that then flyback transformer may b faulty. repalce it with same one.
Posted on Sep 07, 2010
793MB flyback went off.
bad power supply, a blown out transistor,diode, but check horizontal output first..
take it out, then test again,,if its stops ,and power light comes on,, then change h-output transistor.
Mar 05, 2014 | Samsung SyncMaster Computers & Internet
My monitors light is blinking with a tick tick sound
Possible fault is A) blown LopT driver transistor, B) some of the rectifying Diodes in Power supply is short or open, thus not suplying needed voltage to circuitry. Also check all electrolytic capacitors in PSU circiuit & around Lop T. If any of them is geting hot or olstic cover is cracking or shrinking , or capacitor is bulginh\g on top.... Replace.
Oct 04, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
No picture, power led blinking, ticking sound in an LG 702b monitor
our both the monitor having same diffect.
Out put transistor will be short.
replace it and check the other parts in the horizontal section
Aug 02, 2011 | SAMTRON 55V 15" CRT Monitor
My samsung syncmaster 794 monitor light is blinking but monitor not get on
If you tested that to another working CPU but the same problem before, i think that monitor has a problem in horizontal section, check the B+ atlaest 175v if is it normal the power supply is ok, check the H.O.T horizontal output transistor, remove or hang the 3 pins then power on the monitor, if the led did not blinking the H.O.T has fault may be leak,open or shorted.
Sep 28, 2010 | SAMTRON 55V 15" CRT Monitor
IT goes into black mode.. seems completely stalled and it clicks none stop. I could after a few off/on it was coming back but now... it's completely dead... the monitor is not even 2 years old...
Most LCD monitors fail after a couple of years!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 16, 2010 | Samsung SyncMaster 2493HM Monitor
Display (compaq 7500) is dead and there is a ticking sound from
Check the HOT also check to see if you have B+ voltage line looks like either fbt or output transistor.
Dec 27, 2009 | Compaq CV 7500 17" CRT Monitor
No power
That ticking is from the power supply section of the monitor. It means there is a short circuit somewhere in the unit. Usually this is a part called the horizontal output transistor, which is mounted on a metal heat sink somewhere on the circuit board. It is possible to repair by replacing the transistor with the same part number (the number is on the transistor). Sometimes other parts are bad too, though, so the repair could be more difficult than that.
Nov 21, 2008 | Computers & Internet
My TV
the old ticking sound... yes.. it means your power supply shut down and continously trys to reboot ... hense the tick sound as the voltage rises and fails.
Means you got a short somewhere. Most likely the obvious high power consuming High Voltage Suppy... and as I found in 99.9 percent the Horizontal power Transistor shorted... 80 percent Flyback, 10 percent audio... 10 percent some odd circuits like vertical or yoke as shorted.
you have a short.
Sep 10, 2008 | Sanyo DS24424 24" TV
Toshiba CF3566A Tac 9190
the cuestion is if every time it shut down you have the hot shorted,or not. have measure the flyback/yoke/Hot working current? it must be under 0.6Amp ,if is greater something is wrong and cause overheating.Normally I touch with my fingers to "measure" the temperature. and what about the Micro?.there´s one pin that control power on/off ,is it good-solid data or is crazy . micro gets hot, have a correct 5Volt on its VDD pin. lot of cuestion that I hope helps you!!!
Jul 08, 2007 | Sony HMD A220 17" CRT Monitor
Toshiba CF3566A
follow the diagram, the base of the hor out should go to the secondary of the hor drive transformer, and going to the primary circuitry you should find a transistor, a small transistor, look for its collector and you should find a filter capacitor, may not be the same value but it is the filter capacitor.
May 20, 2007 | Sony HMD A220 17" CRT Monitor
Samsung SyncMaster 793DF 17" CRT Monitor Logo
228 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
