Question about Hitachi DV-PF2U DVD Player/VCR
If the red light does not go on after the DVD is inserted, could the laser mechanism need to be replaced. I tried an air compressor to clean the lens, and a lens cleaner produces a NO PLAY message.
  • 10,515 Answers
Unfortunately - you seems to be correct. The symptoms you mentioned are highly suggestive of faulty lens. The replacement would solve the purpose as you have tried all DIY tricks like cleaning the lens as well as using lens cleaner.
However, in today's world, i would suggest you to invest the money in new player than to get this repaired. There are couple of reasons for the same. First, it is not easy to get the original lens. You might need to use after market lens or similar lens. There is never a guarantee that it would work for more than a certain duration.Secondly, the cost of lens and the time you would spend is not worth repairing it. There are so many new players you could get even under $50.
If you want to repair it, buy a used non working player :-
http://cgi.ebay.com/Malfunctioning-Hitachi-DV-PF2U-Combo-VCR-DVD-Player-/400150795575?pt=DVD_Players_Recorders&hash=item5d2ad89537
Make sure that the lens is fine in that player. I would say it's worth buying the above unit ( make sure that the lens is fine in that player as i have not checked the conditions ) if you really wanted to repair it.
Note - It is really not worth to send it for repair as the repairman would charge you around $50 - $100 labor + parts.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2010
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model #...
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Koss KS4110 DVD Player
PHILIPS DVD 3007. IT SHOWS NO DISC DISPLAY WHEN DVD IS INSERTED
Good luck.
Apr 09, 2011 | Televison & Video
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
The player keeps loading and does not play the disc.
All you need to do is to open the DVD player, clean the lens with a cotton bud soaked with Some isopropanol alcohol, use this to clean the lens, but if otherwise, check the ribbon cable that is use to connect the laser lens to the circuit board , if this the ribbon cable is okay the lase lens will popup a red light indicating the lens is well connected, and if otherwise you have to replace the DVD DRIVE, the DVD DRIVE come with a whole of a mechanism and laser lens. This will solve the problem .........
Aug 08, 2010 | Hyundai Televison & Video
RCA - Dvd - Video Cd - Cd Mp3 Decoder : Model# - DRC220N Problem - When disk is inserted, it says "Reading Disk". Then says "Incompatible Disk", Then says "No Disk".
Have you already tried to clean the laser pickup lens?
If not, then maybe you should try (there are youtube videos explaining it).
If the unit has been operating for a few years or so and if cleaning the lens doesn't solve anything, then the next most likely problem is the spindle motor which needs to be either cleaned (which is a bit difficult) or replaced (which is either less difficult than cleaning or entirely impossible). The other motor that can cause problems is the slide (laser pickup position) motor, but if the buildup of the disk mechanism makes it impossible to replace the motor(s), then unfortunately the only solution is to replace the entire disk mechanism.
regards
Triarcuate
Sep 29, 2009 | RCA DRC220N DVD Player
My ps3 stopped playing ps2 games
Hi, it sounds like your laser may be dirty or need replaced. First try to run a laser lens cleaner through it. If it won't read the cleaner, then try to blow out the DVD drive with some canned air or with an air compressor. If that dosen't help then your laser is probably burned out and needs replaced. This is a very common problem with the PS2 and PS3 systems. Remember that a PS3 has 2 lasers in it so it might still read Blu-ray discs and not anything else, but the red laser for the DVD,CD,PS1&2 games might be burned out.
Aug 11, 2009 | Sony Playstation 3 (PS3) Console
When i put in a disk it says no disk
check and see if the cd isnt stratch up or make sure your dvd is clean in the tray try cleaning the dvd player or the cd
Aug 05, 2009 | Televison & Video
My xbox 360 elite does not play games at all
well lets start with the simple stuff first. Have you tried to clean the laser with canned air or an air compressor? Try blowing air inside the DVD drive and see if it had dirt or dust on the lens. If that dosen't work, then you quite possibly need to replace your laser. It isn't very costly (maybe $25.00 tops) for the laser.
Jul 18, 2009 | Microsoft Xbox 360 Elite Console
No Disc
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Pioneer DV-270-S DVD Player
Will not play dvds
YOU MAY HAVE A BAD OR DIRTY LASER LENS TRY CLEANING LASER LENS WITH CANNED AIR THEN TRY IF THIS DOESNT WORK YOU PROBABLY HAVE A BAD LASER LENS especially if it isnt lighting up red
Sep 08, 2007 | kawasaki PVS-10921 Portable DVD Player
Hitachi DV-PF2U DVD Player/VCR Logo
123 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
