Question about Bissell Powersteamer 1694 Upright Vacuum
I need insructions to replace the pump and brush belts on Bissel 1694W Powersteamer
  • borsar64 Sep 05, 2010
    That gives me access to the pump belt but what about the brush belt? Do you have further instructions?
  • borsar64 Sep 06, 2010
    Yes. Thank you for your time and the links.
    President:
  • 1,961 Answers
See the image below
1. Turn off power switch and unplug from the outlet.
2. Using a Flat head screw driver, insert the blade end into the lower slot of the belt access door to release the lower snap. Insert the blade end to the upper slot to release the upper snap.
3. Examine the belt for breakage. You should be able to see the pump belt looped around the motor shaft.
4. Replace if its broken or missing.
5. Once completed replacement return back the belt access door and power on the unit.
If you still have some questions just post back.
Please do rate my solutions.
Thank you for using Fixya.
Alp
Posted on Sep 05, 2010
  • Danilo Baraquiel
    Danilo Baraquiel Sep 06, 2010
    To replace the brush belt, as soon as you remove the belt access door turn the uni to the side while the access area is facing upward. Look for the red retainer arm that holds the brush arm and toothed brush belt in place. Using a Philip screw, remove the screw that holds the red retainer arm in place. Remove the black brush arm that holds the brush in place. Remove the toothed brush belt form the brush then from the pulley
  • Danilo Baraquiel
    For better understanding here is the actual images and step by step instruction to access and replace the pump belt and brush belt. You must have an adobe acrobat reader installed in your system to view this because its pdf format. See this link http://middleeasten.bissell.com/images/U...
    That is everything you need to know. Please rate this answer. Thanks
  • 944 Answers
To Remove Broken Pump & Brush Belts:
1)Turn the Power Switch OFF and unplug from
wall outlet.
2)Step on Handle Release pedal and recline
handle on floor.
3)Remove the Tank-in-Tank. Set aside.
4)Remove the Belt Access Door located near the
Ready Tools Dial. Insert a Flathead screwdriver
into the slot nearest the handle to gently pry off
the door.
5)Turn the machine onto its side so the belt
6)On the bottom of the machine, near the belt
access area, is a red retainer plate that holds
the black brush arm and brush in place. Using
a Phillips head screwdriver remove the screw
that holds the red retainer plate in place. Set
red retainer plate and Phillips head screw aside.
7)Remove the black brush arm that holds the
brush in place. Set the black brush arm aside
(see illustrations).
8)Remove the "toothed" Brush Belt from the
brush then from the red pump pulley. Set the
"toothed" Brush Belt and brush aside.
9)Locate and remove the broken pump belt.
To Install The Replacement Pump & Brush Belts:
1)With the unit still on its side, loop one end of
the replacement Pump Belt around the red
pump pulley and the other end around the silver
motor shaft. Do not twist the
replacement Pump Belt.
2)Re-install the "toothed" Brush Belt first onto the
red pump pulley and then onto the "toothed"
end of the brush
3)Re-install the brush into the base of the unit.
4)Place the black brush arm onto the brush and
slide black brush arm into original position.
Re-install the red retainer plate and Phillips
head screw.
5)Using your finger, gently spin the replacement
Pump Belt on the silver motor shaft.If assembled correctly, the
replacement Pump Belt should rotate freely
around the silver motor shaft and drive pulley
without obstruction. The brush should also rotate
freely when the silver motor shaft is turned.
6)Turn the machine right side up. Replace the
Tank-in-Tank and Belt Access Door.
Assembly is now complete.
Here is the user manual about how to replace the pump and brush belts
Click here to download
Page no 15 and 16 will guide you with pictorial representation.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 06, 2010
    If the problem is solved do vote for me thank you
Model 07142C on my Bissel PowerSteamer pro Deluxe The Brush is not rotating
You could have a broken or loose belt. Check your User Guide for troubleshooting if that doesn't work call the Consumer Care at 1-800-237-7691 Hope that helped.
Oct 09, 2014 | Bissell Vacuums
Need to replace a brush belt
Accessories and replacement parts for your Bissell 1697 Powersteamer Pro are available here:
http://canada.bissell.com/Products/p/powersteamer+pr/ak/replacementparts/Product.aspx
Your User Guide is also available at:
http://canada.bissell.com/images/UserGuides/1697C.pdf
Refer to page 15 for instructions on how to replace your brush belt.
Apr 03, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Is there any reason the water won't come out?
You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
Bissell Powersteamer Belts
Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
I have a Bissell PowerSteamer ClearView How do I
I removed the pump belt and the brush drive belt for replacement. I can see that the brush belt has little ridges to line up on the brush gear. Its the pump belt that I need help with. The flat belt goes over the shaft sticking out of the pump, but the other end appears to have a channel that the belt fits into and around. Only when I put it togeather that way the belt is off center, does the belt fit up over the rounded (pink) end before the channel or is it supposed to fit in the channel
Jan 05, 2010 | Bissell 8806 Powersteamer Upright Vacuum
How do you replace the pump belt?
To install a new belt you need to unplug the unit first and flip that bad boy over so you can acess the bottom of the unit. You will need a phippilps or torks driver to remove the scres towards the front where the brush is. Once you pull all this out the belt will be attached to the brush and a small pin in the back. It is really simple. Hope this helps out.
Aug 23, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel 1695 - pump not turning on. Vacuum turns on
bad switch or connecter at switch or the pump is plugged
Feb 22, 2009 | Bissell 1695 PowerSteamer Vacuum
Dont know how to change the belt on a 1697 bissel powersteamer pro
There is a great video on the Bissell site. 1 min watching it shows you how.
Basically you unplug it, take out the tanks, turn it upside down, remove the 2 red clips that hold the brush assembly, and lift the assy out, then replace belts.
Here's the address
http://www.bissell.com/Products/c/Upright+Deep+Cleaner+Accessories/p/proheat+belt+accessory+pack/product.aspx?MSCSProfile=2EB09F17E7A640E9CB747DEC04C54923ABEBC461914E4B4958096E12DCE8A1EBC0D7023A1D7484587BE6FFD0D4372F71BDAEC9636E63BE9D70638FF56AA7AD996BB994E65B569C57A48747A4845C7AA606787ADFE6D2ABCDB2992ADEF12B6E305AFD4B2D990F331DD44009B45BA4FD9D80C0E6A91684918DAC692BC655419173FF07ACCE5D43B1B3
May 03, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a bissel carpet cleaner and the brush does not rotate when machine is on.
The brush roll is driven by a cogged belt, the brush roll will also have these cogs. If they look all right, then check the end of the pump, it has a dual pulley on it, one for the flat pump belt, and the other for a cogged belt. If the cogs are wore away or that part of the pulley broke off, then you will have to replace the pump. That pulley only comes with a pump.
Mar 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Belt removal Bissel PowerSteam ProHeat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Powersteamer 1694 Upright Vacuum Logo
399 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
