Question about GE WBVH6240F Front Load Washer
I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type smell. Any Suggestions?
Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
Posted on Sep 08, 2010
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
I bought a GE front load washer last year model # WCVH6260HWW now I'm having problems with it. It keeps shutting off during a load. I push the Start/Pause button to get it going again, sometimes 3 or 4...
I have the same problem, and I believe it is because the filter is full. I'm tracking down the repair process now.
PUMP FILTER CABINET, COVER & TOP PANEL 285 WH23X10029 $68.00
I've downloaded the exploded view from GE.
Jul 01, 2009 | GE Washing Machines
I have a 4 years old GE top loading washer - model number 2090D... it was fine till last night that it stop at the last ''drain and spin'' cycle... and I smell a burn smell too when I notice the washer...
  It may be possiblr by the way you explained the symptoms, that the tomer may have shorted out .That would be the most likely problem of the burning smell,and the case of no water entering the tub .
May 02, 2009 | Washing Machines
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
GE WBVH6240F Front Load Washer Logo
958 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
