Question about Rockford Fosgate Power 1500BD Car Audio Amplifier
My name is andre i think i fried my power 1500bd mono amp. I would like to get it fixed who can i send it too? My problem does anyone fix old school amps?
5 Suggested Answers
Duncan
  • 218 Answers
SOURCE: amp won't turn on don't know if amp is fried
Very possible that you have a blown power supply in the amp. If you are running a mono amp then there is a very good chance that you have loaded your amp with too low of a speaker impedence and fried the power supply and maybe the output section of the audio area. Hope this helps.
Posted on Apr 02, 2007
zzedly
  • 300 Answers
SOURCE: green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Posted on Mar 16, 2009
zzedly
  • 300 Answers
SOURCE: Need Specific Specs on JBL 350.1 Mono Amp
Keep in mind the input current to the amp is not continuous. Yes, the fuses on the 3501 are rated at 2x30A, but that means that at any one time, if the peak current goes above 60A, (theoretically) a fuse should blow. But in reality, the amp will draw much less current than that under normal operation. Even by adding the 300/4 to the mix, in my opinion, you will be ok.
etirbynnor
  • 655 Answers
SOURCE: Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Posted on Apr 27, 2009
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
My Mackie 808s will only play in Mono. Does anyone know what the problem is and if it can be fixed?
You have a button on the front that says, "power amp routing". If the button is pushed in, the left will power mains in mono and the right will power the monitors in mono. Make sure this button is off for stereo.
Mar 05, 2013 | Mackie Music
Only one channel works on my amp i got it that way from a junk yard how do i fix it
send it to Landis,
Larry there is real good with the old school amps. its also where rockford sends there older products to get repaired,
704-575-2134
Jul 16, 2010 | Rockford Fosgate Punch 150a2 Car Audio...
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Sub Wiring
Hello jtkpay,
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Amp won't turn on don't know if amp is fried
Mar 30, 2007 | Kenwood KAC-8152D Car Audio Amplifier
Rockford Fosgate Power 1500BD Car Audio Amplifier Logo
41 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
