Question about Fuji FinePix J10 Digital Camera
Cant view pictures on my camara - Fuji FinePix J10 Digital Camera
    President:
  • 423 Answers
Not enough info to diagnose, however, if the card has been out of the camera and connected to a computer, often modifications to folders or images render the camera unable to read the card. Rotating or renaming images is the most common problem. It doesn't mean the images aren't there, just that the camera can't read them because the data has been modified from the way it was originally created.
Posted on Sep 05, 2010
Can you view digital camera pictures on the television screen
yes, use the plug that came with camara with ends, 1 plugs into camara, the other end will have an rca yellow video plug. plug the yellow into your aux video in on your tv. you will use the functions on camara to view, skip, etc.
Apr 01, 2011 | LG 32LG30 32 in. LCD HDTV
Cant get my computer to load pictures says i need a disk
You should have had a soft ware disc with your camara to down load on to your computer so it can reconise your camara to download from.
Aug 29, 2010 | Cameras
A 730 digital camera pink GE
It sounds like you've had an incredible run of coincidental luck. Although this problem does happen, it doesn't happen that often. Could it be that it has gotten sat on, even while in a camera case? (I'm stating the obvious) They cannot be flexed too much. The lcd panel on the back is quite hardy, but the connection is a little more sensitive. Sorry I didn't have a definitive answer for you.
Jan 06, 2010 | Cameras
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
Lost the disc to load onto a new computer+ video does not play
Please write the modelnumber and i send you the install disk and manual and send your problem again to FIXYA
Apr 05, 2009 | Cameras
File Error
my camara when I see or viewed the picture same of they are bad with lines and same videos says error and I can't see it
May 18, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
How do you take a picture
Does anything happen when you press the snapshot button (not the video record button)? If not, you might have a defective camera.
Dec 12, 2007 | Aiptek MPVR Digital Camera
My new digital camara
Your lens is jammed. The only way to fix that is to send it into casio.
Nov 06, 2007 | Casio Exilim EX-S600 Digital Camera
Suddenly started taking photo's in the raw formant
Raw format pictures can be viewed only using fileviewer software, the Adobe Photoshop CS software program can already read raw file pictures. To change settings just push menu, look for the settings you want to set up. All digicam are user-friendly. If you cannot activate the menu button then your unit has a problem and needs to be serviced.
Aug 26, 2007 | Umax AstraPix 430 Digital Camera
Black screen when camara is in photo mode
anyone else had this? or know what to do. whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Jun 24, 2006 | Fuji FinePix S304 Digital Camera
Fuji FinePix J10 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
