Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Spindle bolt broken - Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
  • 4,348 Answers
Well, that is all she wrote on that saw. Cheaper to replace it.
Posted on Sep 05, 2010
When replacing idler pulley on 54 inch mower deck we busted the bolt off . Is the bolt welded on or does it screw off
didnt specify what make or year on deck -----can be a bolt --spindle bolt --welded spindle bolt top --welded stud if you can access the bottom and feel for a bolt head or will have to drop unit anyway to remove the broken bolt can check and observe the under deck
Aug 24, 2016 | Garden
Broken thread spindle
drill a hole into the center of the broken spindle, use a tap (from a tap and die set) and get the broken bit out. Buy a new spindle and put it in.
Feb 25, 2013 | New Home Sewing Machines
On a 1995 f-150 4wd, does the caliper anchor bracket bolt on to the spindle, or is it on peice? I have a bolt broken off in the brake caliper and wondering if I can change the bracket, or have to dril
brka calipers are bolted on to the anchor point because you have to remove them to get the disc off. Normally you can remove the bolts and lift the caliper off the disc. If the broken bolt is in this part the next step is to place a hose clam on the brake line to stop fluid leaking out when you remove the caliper for repair. Drill out and use an ezi out tool . Remember that replacement bolts have to be grade 8 quality by law.If the broken bit is in the anchor point simply push the caliper out of the way and drill . The bolt still has to be Grade 8 quality
Feb 03, 2013 | 1994 Ford F150 Styleside Supercab
Replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Jun 02, 2012 | Mtd Garden
Bolt broke off when trying to take blade offhow do i get the broken pice out
if it is broken flush you must drill out center of bolt and use ez out or bolt extractor. may want to soak with penetrant or heat bolt before using extractor,if it wont come out you will have to drill out to size of bolt and re thread ,last option replace spindle . hope this helps
Jul 10, 2010 | Garden
2004 F150 4X4 caps over both front axles and bolted to the inside of the spindles, has what appears to be a double vacuum hose going into it. They are either broken or corroded from their flange bolts onto...
Sounds like the IWE ( Integrated Wheel End ).
One of the lines is the vent line, routed into the engine compartment and is not connected to anything, the other runs to the IWE solenoid.
This is a block diagram of the IWE vacuum system
From your problem, I am not sure if the line is broken or the vacuum & vent mount on the IWE itself.
Jul 01, 2010 | 2004 Ford F150
How do you replace the front rotors on a 1996 honda accord?
Remove wheel. Take off outer driveshaft nut. Remove lower ball joint pinch bolt & separate ball joint from spindle. Pull rotor & spindle out & away to pull driveshaft outer splined end out of rotor center hub. Look on the back of the spindle for the 4 bolts that hold in the wheel bearing. Use a 12 point socket to remove the 4 bolts and remove wheel bearing from spindle (out towards the wheel stud side). Probably will have to use a air chisel to get it out. Once it's out undo the 4 bolts on the outer (wheel stud side) of the rotor and remove the rotor from the hub. Clean & lube the hole where the bearing was in the spindle & the inner face of the hub. MAKE SURE IT'S CLEAN otherwise you may get a pulsation on braking if theres a piece of rust or dirt between the rotor center & the hub face. Reverse procedure to install.
If the rear bolts don't come out then you will have to use a slide hammer to separate the bearing to replace the rotor and there is a very good chance you will need to replace the wheel bearing after you're done (noisy on road test).
Not the job to do at home, usually an easy 2-3 hours per side if things go bad (book time is 2.2 hrs per side). Use good quality rotors as you don't want to have to do it again because a cheap rotor gave you a pulsation.
May 28, 2010 | 1996 Honda Accord
Rear tire lug bolts
You have to remove the tire/wheel assy. remove the brake drum, you will see the spindle with the bolts there. punch out the broken bolts install new buy pushing thru the hole.Find some regular nuts that will fit over the stud, put your new nuts on and tighten up till flush in back.
Jun 07, 2009 | 2003 Chevrolet Cavalier
On the Bench Oscillating Spindle Sander how do you lock the spindle so that you can remove the bolt at the top to change the sanding sleeve? When I try to loosen the bolt the spindle turns and I don't have...
Remove the spindle from the machine itself before you change the sanding sleeve. There should be a flat section on the bottom of each spindle that you can hook a wrench on to hold it while you undo the top bolt.
Mar 09, 2009 | Delta Machinery ShopMaster SA350K Bench...
Broken Lug Studs
You have to remove the hub to remove the bolts, if they won't come out by rotating the hub.
To remove the hub, take the cap off at the center of the hub (the cap would be poking you a the center of the hub, and is about 2 inches in diameter.
There should be a cotter key or something preventing the spindle nut from turning. Remove it. If there is a cover over the spindle nut, remove it. Take the spindle nut off. Pull lightly on the hub, and it will come off. Watch for the front bearing to pop out.
To reassemble, put hub back on spindle, put bearing and washer against bearing, thread on spindle nut and tighten while rotating hub. Back off 1/2 to 1 flat add cover (if used) and install cotter key.
Jan 29, 2009 | 2004 Jaguar S Type
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
