Question about Kenmore Microwave Ovens
What the code f3 mean my stove model # is 911.9584991
  • wfgarrison Sep 06, 2010
    This is not a Microwave Oven its a conventional oven or does it matter do all the codes mean the same thing ? And thank you so much for your help
  • 10,515 Answers
This model ( Kenmore ) has been built by Roper ( 911 - First 3 digits tell you the manufacturer's name ).
F3 refers to Oven temperature sensor open.
You need to check the oven temperature sensor.The value of oven temperature sensor should be around 1100 ohms at room temperature. In case, it is too high or low, you need to replace that.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2010
  • taran_2005
    taran_2005 Sep 06, 2010
    Thanks for your response!!
    I gave you the solution as per the model number :).
    Hope i helped you.
GE JES2150MRSA f3 code microwave turns on by itself,beeps out of control starts cooking by itself f3 is a control panel error
"F3" means you have a shorting membrane keypad.
Looking at the parts list for model JES2150MRSA, only the glass turntable and turntable support are listed, so it appears this is one of those unsupported "doorbuster" models.
If it's still in warranty, it can be exchanged. If not, it should be disposed of.
Mar 15, 2017 | GE Microwave Ovens
- "F3" means you have a shorting membrane keypad.
- Looking at the parts list for model JES2150MRSA, only the glass turntable and turntable support are listed, so it appears this is one of those unsupported "doorbuster" models.
- If it's still in warranty, it can be exchanged. If not, it should be disposed of.
About 1 hour into the 4 hour clean cycle an alarm started gong off. Code is F3. Frigidaire smooth top electric slide in stove.
The F3 code means
The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. Check oven temperature sensor, 1100 ohms Good Luck
Nov 27, 2010 | Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    GE stove displays F3 when i turn on oven
    Well the "F3" error code means the oven sensor is open an ohmmeter reading for the open circuit should be "?". The part number for the oven sensor is AP2023862. Or the harness to the sensor could be open or shorted. You will need to use a meter to check the sensor circuit wiring harness in order to come up with a final diagnosis. You will need to access the EOC electronic oven control & check the sensor circuit from there for a starting point. The value of the sensor should be 1090ohms
    You may purchase the senser from the link below -
    http://www.appliancepartspros.com/part_details.aspx?part_id=2023862
    Check out the below link for digram (most like as your model) -
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=211452
    Good Luck!!
    Thanks for using FixYa!!
    Oct 13, 2010 | Microwave Ovens
    Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
    Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
    Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
    these are some other code error that will help you in case of next time.
    1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
    2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
    3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
    4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
    5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
    6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
    "F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
    Take care.
    May 11, 2010 | Microwave Ovens
    It has an f3 code on it what ledoes it mean
    F3 means fault code number 3, I think this is Power Supply, or Magnetron.
    Feb 09, 2010 | Samsung MW1030WA Microwave Oven
    My ge microwave is showing a code of F3. model JES1034 what does this mean?
    hello there
    Tthe f3 code is referring to a faulty touch pad which may need to be replaced i would contact the manufacture of this microwave for a parts replacement
    Jul 29, 2009 | GE Microwave Ovens
    Microwave Ovens Logo
    127 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
