Question about Ryobi Cultivator
Hi - I need a manual for Ryobi cultivator GC430. can you help?
pranaclimbin
  • 50 Answers
SOURCE: Ryobi ry60514 tines won't turn
there are shear bolts that hold the tines on. they are designed to snap when u hit something big such as a big rock or pipe or something like that. they are designed to snap at so much pounds of pressure so u dont break any gears or gearshafts. a lot of times people dont realize this and put regular screws or bolts in it and run it. when they hit something they ussually snap the gearshaft inside the tiller. i have replaced this on my fathers tiller cause he did the same thing. so either u might need to put new shear bolts in or if u had a regular bolt in u probably snapped a gear shaft or a gear.
Posted on Dec 04, 2008
  • 1632 Answers
SOURCE: unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Posted on Jun 02, 2009
  • 112 Answers
SOURCE: ryobi 410r cultivator needs intital carb adjust
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Posted on Jul 15, 2009
rustysheriff
  • 344 Answers
SOURCE: gas lines on ryobi cultivator
Exploded view:-
http://www.outdoordistributors.com/pdf/Ryobi/RYOBI-410.pdf
Did you replace the gasket (item 15 on the linked document) when replacing tank and lines, if you didn't and the old one has been torn it could be sucking in air, also the 4 carb mount screws need to be of equal tightness
Posted on Apr 23, 2010
I just bought a returned Ryobi GC430 at a reduced price at Home Depot. I took it home and topped off the oil, which was a little low, and put fresh gas in it. I finally got it running but the tines will...
Ryobi engines have a plasic camshft that when it get hot melts the lob off the exshast end and the engine wont run if it cant exshast remove the valve cover and you will see for yourself
Atlantis Small Engines
Aug 17, 2010 | Ryobi Cultivator
START PROBLEMS
I can't post a .pdf here. I have the manual. You have to get it yourself thru that link
http://search-manual-online.com/download/manual/RYOBI%20GAS%20CULTIVATOR%20MODEL%20NO%20RY60511A%20REPAIR%20SHEET/aHR0cDovL2lwbC5vcmRlcnRyZWUuY29tL2lwbC8zMzgvUlk2MDUxMUFfNjg5X1IucGRm
May 11, 2010 | Ryobi Cultivator
Manual for the Ryobi.
Here is a link to parts listings, when searching put in the work Cultivator and it gives you a few options. Hopefully the pictures will let you decide which one is yours.
http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
Here is a link to find a dealer in your area that can help you http://go.mappoint.net/homelite/PrxInput.aspx
good luck Tom
Jul 29, 2009 | Ryobi Cultivator
Ryobi 410r cultivator needs intital carb adjust ments,where do i start,how vmany turns on idle and high idle?
Jul 10, 2009 | Ryobi Cultivator
Unable to start Ryobi 410r cultivator
Vitally
Jun 02, 2009 | Ryobi Cultivator
Gasoline/Oil Mixture
I would not run it any any less that  50/1 ratio.
May 09, 2009 | Ryobi Cultivator
Need To KNOW What Mixture Goes In My Cultivator
hi hnmizen,
mixture will depend on what you wanted to use, there is no specification of how and what to mix.
here is the manual
http://www.ryobitools.com/product_manual/file_url/281/UT15550B_934_eng_00.pdf
hope this helps.
regards
voodoo
May 06, 2009 | Ryobi Cultivator
Need to know the spark plug gap for ryobi model no. ry60511A
Ryobi RY60511A
Champion plug RCJ6Y - gap is .22
I have original manual.
Apr 18, 2009 | Ryobi Cultivator
Ryobi Cultivator Logo
289 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
