Question about Samsung SCX 4600 multifunction Laser Printer
How do you turn it off? no instructions with it except on CD which I can't open.
  • 6,831 Answers
Hello
OK, at the link below you will be able to download the manual.
Click HERE to navigate to download page.
Kind regards
Andrea
Posted on Sep 05, 2010
Tip
Solutions for exception Processing Message c0000a3 parameters 75b6bf7c 4...
Many of you might have faced issue called windows – drive not ready and a message ” exception Processing Message c0000a3 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c” right below of that. It will keep disturb you every now and then even if you close this number of times This normally happens when you remove a drive like Floppy drive, CD Drive or Pen drives from its working conditions without proper instructions. You will get this error message when you remove a CD/DVD from CD/DVD drive during a process happening form CD/DVD like installing software or accessing files etc.
In that situations the programs seeking the files from the drives but its not finding there.So we are getting this error.
You can see the error below.
Here is the steps to solve the issue:
a) Simply put a CD/DVD in to the CD/DVD drive and click on Continue.
b) Open the CPU box and make sure all the data cables connected properly.Like data cable for Floppy drive and CD/DVD Drives.
c) Go to BIOS and disable the Drives which you are not using. Nowadays mostly nobody uses Floppy drive. So you can disable Floppy drive. You can disable unused IDE or SATA ports in bios.Save the settings and restart your PC, Now you will not get the annoying pop ups now.
on Jul 03, 2010 | Computers & Internet
My old bang&olufsen beosound 2000 is working except the cd doesn't want to play - it loads and even moves but quickly opens back up.
My old bang&olufsen beosound 2000 is working except the cd doesn't want to play - it loads and even moves but quickly opens back up.I have the same problem. I don't understand. Cristian
Jul 07, 2010 | Audio Players & Recorders
Missing operating system on Mobile AMD Athlon(tm)XP-M1800
Open the cpu cabinet and then check whether the connectors of the Hard disk and the Cd Driver are in good position or not.
remove the connectors and then reinsert it.
your system will be working fine.
Feb 01, 2010 | Computers & Internet
Disk stuck in j drive, no pin hole
GO TO DEVICE MANAGER AND SEE IF THE DRIVE IS WORKING.IT MOST LIKELY IS SO TURN POWER OF PC OPEN THE SHELL ON PROSESSER AND TAKE DISC OUT,KNOW BEFORE YOU PUT SHELL BACK ON TURN POWER BACK ON DO NOT TOUCH ANYTHING EXCEPT THE DRIVE SEE IF IT OPENS OR CLOSES.IF IT DOES NOT,SHUT POWER OFF AND UNPLUG DRIVE THEN PLUG IT BACK IN.PUT SHELL BACK ON AND SEE IF DRIVE OPENS.IF NOT THE DRIVES FAULTY...HOPE THIS HELPS
Nov 30, 2009 | E-Machines emachines (emachinees) CD-ROM...
I was formating my philips PC and computer was accidently turned off before process was completed. Unable to load vista now as system recovery file is missing or corrupted.
Reformat it again. If it doesn't try the OS of service pack 3 black. Or format it again with your Vista, Check the boot priority on your Bios. Disable all listed except the DVD/CD rom/ram Then load your DVD/CD then follow the instruction.
Apr 05, 2009 | Computers & Internet
Open & close button Does not work
Being that it is an old unit, even though it worked just fine except I had to open and close the drawer by hand. I sent it to the trash bend, It was an Onkyo C110. Thanks anyway!....Bob
Nov 19, 2008 | Onkyo DX-C340 CD Player
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Tray won't open, no buttons work
Return it. do not open it up or you will void any warranty. There is either a disconnected cable or a logic/power problem. In any case, a new piece should work out of the box.
Dan
Apr 10, 2008 | Numark MP-102 CD Player
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Samsung SCX 4600 multifunction Laser Printer Logo
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
