Question about Bell Technology Creative Technology ZEN X-Fi Digital Media Player
Power supply failure - Bell Technology Creative Technology ZEN X-Fi Digital Media Player
  • 3 more comments
  • cw0516 May 25, 2008
    My Zen will not turn on. This happened right after I was downloading from the computer. It was working fine then just shut off. I have tried unplugging it from the comuter. Waiting and trying again. Pluggind it in to a different computer. Not sure what else to do.
  • srhynes Aug 13, 2008
    I was listening to my zen and it just shut off i can not turn on my i charged it for six hours still i do not have use of it what should i do
  • dejonj Nov 19, 2008
    RCA will not turn on
  • Anonymous Dec 23, 2008
    no power will not turn on
  • wingerliz Jan 02, 2009
    unable to see any form of life in my Zen x-fi after downloading
Solution is press reset...
Posted on Jan 02, 2009
Get a new devise that is always a good solution
Posted on Jul 13, 2008
My digital music player will not turn on.what should i do?
Posted on May 12, 2008
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
No power at all
Possible that the main controller has failed if there is power till within the power supply unit of the controller.
You need to probe into the power supply unit to confirm for a fuse failure, a link failure on the Low tension circuit, a failure to provide power to the controller.
Dec 31, 2012 | LG WM1814CW Front Load Washer
Monitor does not turn on
The most common cause of power issues with that model is a dead power supply resulting from a failure in the capacitors on the power board. This is a very easy repair. You have to replace the 6 filter capacitors on the power supply board. The capacitors on the power supply board should be flat on the top and when they fail the tops will bulge showing failure. You can open the monitor up and look at the power supply board and check for the bad capacitors to verify the failure point. Here is a link to some information and parts kit to repair that board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps.
Jun 20, 2012 | ViewSonic Computers & Internet
I have three red lights
Hi, Three red lights on the Xbox 360 is otherwise known as the Red Ring of Death. It's either a power supply problem or a hardware failure. Microsoft outlines here: http://support.microsoft.com/kb/907534 how to test if its the power supply. If it's the power supply you can contact Microsoft and request a new power supply. If it isn't the power supply then it's a hardware failure in which case you need to submit a console repair request. Hope this helps =)
May 18, 2011 | Microsoft Xbox 360 Console
The computer suddenly shut down & will not re-boot. On turning on there may be a few seconds to allow option of opening up in safe mode which is applied but within a few seconds the system shuts down...
Bad Power Supply.
Weak voltage power rail.
One of the leading causes of computer failure.
Replace the Power Supply.
[The next cause of failure is the computer is dirty inside, as well as inside the Power Supply's case.
Dirt, dust, etc, takes a Power Supply down quick ]
Need guidance of how to replace your Power Supply, or guidance in finding a decent replacement Power Supply let me know in a Comment.
Regards,
joecoolvette
Dec 02, 2010 | Packard Bell Computers & Internet
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
My dell GX 1 optiplex pc is not powerring and power supply is not
Hi:
If you don't have the LED lit up on the board, the most likely failure is your power supply. You should be able to get a computer store to test it, to be sure, but a replacement is $30-40
Nov 24, 2009 | Office Equipment & Supplies
50 in LG turns on and then clicks and turns back off
The power supply is going in to protect mode. Most often this is a power supply failure, or a failure on one of the circuit boards that is causing the power supply to go in to protect.
If the power supply fault is not too complicated an experienced tech may be able to service it without changing the compete circuit board.
The tech will service this by substituting boards to determine where the failure is occuring. Then he will change the board to fix the fault.
Jerry G.
Jan 18, 2009 | LG 50PX4DR 50 in. Plasma TV
My Compaq Presario will not start since we had a power failure in our town yesterday. It seems like it is unplugged, but it is plugged in. Can you help?
Can you check if the power is connected to the ac outlet, and if the cpu has a power. If no power in the cpu even the power cord is pluuged in the outlet of the power source the problem is your power supply. Maybe the fuse blow up when the power is back after the power failure. But sometimes the cpu has no power but the monitor have a power it's also power supply failure the dc output of power supply is not working. the best solution is to replace the power supply with the same wattages or higher.
Apr 15, 2008 | Computers & Internet
Bell Technology Creative Technology ZEN X-Fi  Digital Media Player  Logo
125 people viewed this question
Top Bell Technology Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a Bell Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
