Question about KitchenAid Dishwashers
Pump to discharge water is underpreforming. won't empty standing water in bottom of unit when cycle is over. will dichsrge water when dicharge tubing is lowered to downhill slope. can hear motor running
  • 4,341 Answers
Disassemble the drain and pump area, you will mostlikely find particulate matter restricting flow.
Posted on Sep 05, 2010
Testimonial: "We figured it out before your posting but you were absolutely correct! the metal connection stem on the sink drain was clogged. "
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
My questions relate to GE Triton DW Model GSD 6660 G00SS My problems are multiple. I have run the diagnostics and all functions seem to be working but two conditions during operation remain a...
After you the drain to discharge the remain water and the tub is visibly dry of water,then you open and load it do you see standing water after you have drained and know it was gone??
If that is the case what i believe your trouble is that where the dishwasher drain connects to disposer under the sink the drain hose is only leading from that nozzle downward,if that is so what is happening is the dishwasher is draining ok but backfilling whenever water runs through the sink. To fix that use a string on plastic zip tie and attach a portio of the drain hose so at one point the drain hose under the sink is higher that the nozzle and water in the sink will longer run into the hose and run upward since water is only going to drain down and wont ever rise on its own.The drain pump is powerful enough to push the drain water up that "HIGHLOOP" very easily.
Good luck i hope this has helped you to fix your dishwasher,
Gene
Aug 08, 2011 | Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
This unit is installed in a very tight area. There is water on the floor. The water lines and discharge line are fine. Just wondering what I might be looking for when I take the unit out of position? Also...
check to make sure your dicharge hose is all the way in the drain when is drains the pump does push the water fast and it might that you don't have it pushed down all the way check that first
Apr 02, 2010 | Kenmore 98702 Stacked Washer/Dryer
It has water in the bottom up to the lip of the tub and won't drain. Lots of water overflowed. We've emptied the dishes out. Now what?
pump is eather out or pluged with food put it into the drain mode and use a shop vac to **** out the water on the dicharge line
Dec 05, 2009 | Dishwashers
After the wash cycle the unit will not empty, according to the feedback on this page they sujest a dishwater cleaner, can you tell me what type and where to obtain it.
I don't know that a dishwater cleaner will solve your problem. More than likely the pump is no onger functioning which is located on the bottom of the unit. When the dishwasher goes into the discharge cycle does it make a humming sound or does it do nothing. All pumps make sound when discharging the water from the basin. If there is no sound present then the pump is not functioning........if the pump is making a humming sound then it is locked up. Let me know please thanks.
Deathstalker
Sep 01, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Wont empty water cant find filter
Remove 3 screws from the bottom front service panel. Pull the panel down...then off. The pump will be in front of you.
Mar 11, 2009 | Hotpoint Aquarius WD63 Front Load...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
Candy a8001 dishwasher
It sound that the problem is cause the water level switch. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Jan 27, 2007 | Candy 24 in. CD622 Free-standing...
Dishwashers Logo
459 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
