My LCD TV has started to have problems with the lamp. It has gotten to the point where the TV is on least than a min. before in goes black. The bulb is going out and I lose sound. It comes back on within 30 sec or so and repeats this cycle. Could I have a bulb Failing or is this a sign of something else. Thank You Curtis Burns
  • cburns60 Sep 05, 2010
    Does this power problem have the control of the whole set? I never lose the the green power light on the front of the set. Forgot to mention tha tin the first message.
    Thank you I will look into this as soon as I can. I hope this is a a simply overheating problem.
  • 11,800 Answers
LCD tv's don't have bulbs, they have CCFL tubes that don't burn they worn out very slowly.
Your problem has nothing to do with them, it's caused by a failing power source - the capacitors have started to age and dry and when they are heated by the normal functioning of the tv they start to conduct some electricity (instead of being isolators) ; that overstresses the source and triggers its protections - the tv stops - the current drops to nearly zero - the capacitors cool down - they become isolators again  - the source restarts, the capacitors heat up again and the cycle repeats.
The tv must be opened, all aged capacitors must be replaced and every other component in the power source checked for damage. I think this is a job for a pro.
Posted on Sep 05, 2010
  • Azrael SRL Sep 05, 2010
    Of course, the power source powers the entire tv. The fact that the power led stays the same signals that this isn't a full failure so the defect might be still small. and isolated on the lower tension lines so check also the connections to the mainboard and the radiators - the tv might be just overheating.
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
My sony kdf-e50a10 stay on for about 3 mins and then the screan goes black and the green light start blinking for about 45 times and the the tv turns back on it do that over and over
It is symptom of weak lamp that has been reached to end of its working hours life yet not broken or dead. Replace lamp in tv to fix this problem.
Lamp replacement procedure is easy and would be written in user manual of tv.
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Nov 22, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
TV Screen has no picture and is black.
That should fix the problem but do not tuch the lamp of the glass because the oil from fingers will mark lamp
Nov 06, 2009 | Samsung Televison & Video
Sony KDSR50 - TV comes on then goes to a black screen - sound is fine. In the 2 or 3 mins of TV visual time, the color looks a bit off - lacking red - could this be a bulb problem? Bulb does not look...
Hi
Its symptom of weak lamp so TV needs new lamp.
Lamp replacement procedure is written in user manual and lamp part number is as follows..
F93087600 Lamp Block XL-5100
Available in Sony Accessories Store, please buy Sony Original Lamp for TV safety.
Jun 26, 2009 | Sony KDSR50XBR1 50" Projection HDTV
TV goes off about every 45 seconds - comes back on picture first
The repair man just left my house for the EXACT same problem on the EXACT same model TV. All he had to do was remove the front panel on the TV and clean the bulb and fan. He said the bulb may have to be replaced before long but it is working perfectly now!! $100 service call to clean the bulb!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
