Question about Cozy (W352E) Heater
How can i turn off my wall heater i already put in position off but the valve is still working
  • 24 Answers
Turn off gas supply but replace valve before turning back on.
Posted on Sep 05, 2010
Need some help. I rebuilt my old wall heater and it won't turn on. New thermopile, pilot and gas valve. The pilot works, but burner won't ignite. New thermostat too.
turn thermostat to off position check wires from thermopile to stat and gas valve for damage etc . Thermopile has to warm up and make 600 mille volts to work . Try this then open stat and see if it fires up .
Dec 05, 2016 | Heating & Cooling
I have had the gas valve, the pilot, and the wall thermostat replaced. I know it's ridiculous because I have spent more than it is worth. The pilot is lit and the heater will still not come on. What...
Have you got the knob turned to the "ON" position? Are you getting 24 volts to the gas valve? Has the gas valve solenoid got continuity between the 2 terminals?
Nov 08, 2011 | Williams (5009622) Ceramic Gas Wall...
My heater switch seems to be stuck on hot air all the time. Replaced switch but same problem.
under the alternator there is a control valve located in line from the water pump to the heater core, your control switch operates this valve via air. have someone or you can do it yourself turn switch to hot,LOL already there,ok locate this valve and notice the position of the rod on valve. now turn control switch to cold position, recheck position of rod again, did it move? pull air line off valve,or follow air line up a little bit and you will find a coupler, you can disconnect it here. while engine is running put finger over hose and check for suction in cold and hot position. Should only **** in hot position. if ok your inline valve is bad. cheap fix
Jan 04, 2011 | 1998 Ford Explorer
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
Nov 27, 2010 | Heating & Cooling
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
How do I lite a wall room heater
First, turn off the gas valve for at least 5 min and ventilate the room. Most wall heaters are lit the same as a water heater. Find a red button to push or turn the gas valve knob to the pilot position. While pressing the red button or the gas valve knob, hold a match to light the pilot flame. After it lights continue holding the knob for one or two minutes. If the flame goes out when you release the knob the thermocouple is probably bad.
Oct 18, 2010 | Williams (5009622) Ceramic Gas Wall...
We have a gas wall heater product number 4690011 and we do not know how to start it;
Remember if you smell gas, turn unit manual gas valve off and open a near by window, wait until smell is gone then proceed with these directions,turn manual gas valve back on, turn thermostat down.1.) turn combination gas valve knob to the pilot position and press down knob, if unit has a striker button, push striker while holding down knob until pilot lights, keep knob held down in the pilot position for 20 seconds then let up on knob and turn to the on position, turn thermostat up, main burners should light.
Mar 04, 2010 | Heating & Cooling
Wall Heater
If you have already changed out the thermocouple and the pilot goes out when the burner goes out, it leads to reason that the gas valve has a weak magnet or that the pilot is dirty. The cheapest thing would be to remove the pilot assembly and clean out the orifice. If it still drops out, you will need to replace the gas valve.
Nov 02, 2009 | Heating & Cooling
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
I have a DESA gas wall heater.
take the heater off and have it blowed out. we did that to ours and haven't had a problem since.
Nov 19, 2008 | Desa International GWP20T GLOWARM Wall...
Cozy (W352E) Heater Logo
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
