My Mitsubishi wd-65375 when turned on will have the status light blink but after a few seconds of the blue Mitsubishi screen it turns itself off. It work perfect until today.
4 Suggested Answers
  • 11800 Answers
SOURCE: I have a 13 year old Mitsubishi tv which worked
The vertical scan module has failed. The tv is easily fixable, but not by you, you will have to call a technician to replace/unsolder some parts. It will cost you around $150 ($25 the parts plus the labor) so must decide if the tv is worth that.
Posted on Jul 04, 2010
welcomejee
  • 10594 Answers
SOURCE: Mitsubishi Model # WD-62725 First, I
Status LED blinks (orange) continuously is an error code that shows that Filter Cover is not attached on tv front.
Make sure it is fixed properly to avoid that error.
Thanks.
Posted on Oct 08, 2010
SD Tech
  • 14553 Answers
SOURCE: My Mitsubishi wd-63527 turns on for a few seconds and shuts itself off.
The set may have (some models) a recessed reset button on front but that rarely does any good.
This model should have two resets other than that one----soft reset if it has it is with Mitsubishi remote: On, Menu,1,2,3 enter.
Set also has a hard reset which requires a four digit number code and resets set back to factory---it is a last resort and should not be done unless the soft one does not help.
I would have the remote tested as without it you cannot do any reset--
Most digital cameras in a dimly lighted or dark room will react on screen display when a remote is pointed at them and buttons pushed or most shops have a tester which will show and react to each and every button when remote is pointed at them and buttons pressed.
This model could have a keyboard lock feature which disables the keyboard but remote should still function.
First thing is to know if remote actually is working or not.
Posted on Apr 21, 2012
Mitsubishi WD-65638 turns itself off and I see no status codes afterwards
Press menu and input on front of TV for 5 seconds. Green light will flash two digit code 5 times. '12' is no error(no problem.)
May 22, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
Sep 22, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Apr 21, 2012 | Mitsubishi WD62527 62 in. LCD HDTV
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
TV is blank and status light is blinking yellow
I think you have a powersupply problem. This model has had alot of problems with bad electrolitic capasitors through out the entire chassi assy. Because of the way the manufacture designed this unit you may be better off getting a Mitsubishi Authorised service company to fix it. If you feel confedent,
check the powersuppy for 2 electrolitic capasitors that are bulging on the top. They will be your culpirts. I believe they will be 25v 2500uf. But don't hold me to it.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Television suddenly turns off.
Try to get a firmware update. THis happened to me and I got a firmware update from Mitsubishi and now all ok. Call Mitsubishi
Nov 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
