Question about Refrigerators
Got a ge 21.7 side by side model number tfh22prsa ww. from a friend said it was working when they took it out. had it in their garage for a year. I cleaned it up. pluged it in, lights on the inside work. but does not seam to be runing. I have the back off fan not runing. Do the have a fuse some where. Thanks dennis also what age is it
5 Suggested Answers
  • 4 Answers
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Posted on Jan 01, 2009
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: model tfh22prsa GE Side-by-side freezer ok refrigerator warm
There are 3 things to look for on the TFH22PRSAAA refrigerator when this happens. First we need to have a look inside the rear of the freezer and see is there is frost build up on the rear back panel that covers the evaporator. If yes you the next thing to do is look inside the fresh food compartment for the defrost timer located behind the control panel as shown in the photo below. I want you to turn the defrost timer clockwise until the compressor motor and fans stop. The refrigerator should be in the defrost mode now. Open the freezer door and listen for crackling and sizzling cause by the defrost heater being on. If there is no sounds or changes the you need to let me know. The timer should turn the refrigerator back on after 25 minutes. If not simply turn the timer again slowly clockwise until the compressor restarts. If you need to do this you will need to replace the defrost timer because the timer is no longer running as a timer and has become defective. I am going to stop here because I don't want you to think this is too hard to do It's easy to do these test and I will be here to assist you. Let me know when you are ready or if you fell you have it under control please rate my solution when were finished the repair, Thanks, Sea Breeze
Posted on Aug 14, 2009
aasc
  • 1606 Answers
SOURCE: my ge side by side model gss25jfmc ww will start
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Posted on Jan 02, 2010
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Freezer at 21 degrees , refer at 44 degrees, will not get any colder.
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Sep 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
GSS22KGPD WW G.E. side by side 21 Cub ft.
You beat me to an answer for you. the freeze up was most likely in the door. you may want to check with GE if my memory serves me corret there is a servie bulletin for this condition. thanks for using fixya Peyton....
Feb 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model TPH 21 PRSM WW not cooling in reefer
The 'baffle' is controled by a small electri motor,This is a renewable part.If you want to manually open it,you should be able to gently move with you hand,after removing the guard. Hope this helps!!
Nov 14, 2008 | GE GSH22JFR Side by Side Refrigerator
Refrigerator will not dispense ice or water.
I have one the same model It done that about a month after I got it.
1995 Year I took of the left top corner the wires that make it work are in it. I wiggeled the wires around untill it started working and folded a card broad and put in it to hold the wires the way I wanted then put the cover back still works to this day.
Worked for me, Thank You,
Sep 02, 2008 | GE Refrigerators
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
