Question about Western Digital Caviar WD2500JB Special Edition 250 GB Hard Drive
WD2500JB HDD FAILED. On board chip U1 burnt out. How can I retrieve data on HDD to another HDD. If card replacement needed, any idea where I can get one from, and how much? Drive details are: MDL: wd2500jb-22gvco date: 8 May 2005 DCM: HSBACVJAH Details on PCB: 2060-701265-001 REV A Sticky label says: 2061-701265-200AH Many Thanks, Simon Young
  • Western Digital Master
  • 9,639 Answers
You're going to need a professional data recovery service to get your files. Just google data recovery companies and find out what they charge. You may get lucky and have one close by.
Posted on Aug 16, 2017
IB4G2008
  • 3587 Answers
SOURCE: slow write speed
hmmm..well...is that 250 Gigglebyte drive, as a slave, on a secondary port, by chance?
Posted on Mar 23, 2008
TIPS72
  • 369 Answers
SOURCE: I have a WD2500JB hard
To be sure your hard disk is ded or just have probs in the casing just try to remove the hd from the casing and connect it directly to the system if its 2.5 tb u would have 2 hard drive orthree please connect all of them to gether to your system other wile it could become unalocated
if it works u have prob in the casing so just change the case .
but before going through all this just connect the hdd and go to disk management by right clicking on the my computer icon go to manage and then diskmanagement if itshown there as forgen or unalocated just let me know i will tell you what to do
thanks and regards
Good luck
Posted on Jan 04, 2009
TimeDefensiv
  • 746 Answers
SOURCE: my hard drive is a wd2500jb and its only giving me
Dear! usa partition magic 8.0 or later software or program and install it on your computer. Now you can get easily your remainnig space and you can also manage your partitions of your hard drive.
Good Luck
Posted on Sep 03, 2009
  • 1738 Answers
SOURCE: My WD2500JB stopped working. Makes a click-click-click sound.
Your hard drive is bad. If you are hearing clicking reptitiously it is you head not moving. Sorry about the bad news.
Posted on Dec 16, 2009
  • 20 Answers
SOURCE: Western Digital WD2500JB (WD Caviar SE) external hard drive died.
Generally drives that "click" and give access errors are not recoverable by ordinary (consumer capability) methods. What has happened in most cases is the "servo track" that contains the underlying data required to access the drive has become worn-out or damaged. The best way to avoid this is to not jolt the drive when spinning, and more importantly - BACK UP YOUR DATA on a regular basis! Sorry to be the bearer of bad news. I recover several drives a week, but have to send off most "clickers" for professional lab recovery, which can be VERY expensive ($400-$2000+up).
Posted on Mar 01, 2010
F105 failed error
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover t he data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
U need to update firmware if replace HDD
Sep 16, 2013 | Toshiba E-studio 281c Copier
I looking for a pcb boad for hd western digital
That would be on another WD2500JB Caviar harddrive
Either that, or start looking on the internet posting -
WD2500JB PCB Board, and see what search hits come up.
Here,.....let me try.............
http://www.hdd-parts.com/18100096.html
Before you replace it, let me ask........
1) Was it in a Desktop PC?
2) Was it in an external harddrive?
External harddrive?
Then suggest you obtain a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3883498&CatId=2780
In an external harddrive there is a small interface circuit board.
The Harddrive plugs into the small interface circuit board, and the USB cable is attached to the small interface circuit board.
It is this small interface circuit board that usually goes bad.
The external enclosure is just like the case of the external harddrive.
Has a USB cable going to a small interface circuit board, and the harddrive plugs into it.
Regards,
joecoolvette
Mar 13, 2013 | Western Digital WD2500JB WD Caviar EIDE...
Hard Drive Crash - wants to re-install how to retrieve data to laptop computer
If the HDD has failed you can't retrieve the data off the failed drive. You can send the HDD into a data recovery company and they will read the disk in the drive and put the info on DVD and sent it to you, but that is the only way. The service is quite expensive. Just do a google search for failed hard drive data recovery.
Jan 27, 2012 | Computers & Internet
When i plug my disk drive to my lap top,it is unreadable and IO error will appear.please note that there is right click option. Do you have any idea how can retrieve it?thank you in advance
The board that connects the external disk to the USB port on the laptop has failed. The only way to try to recover the data is to dismantle the casing, extract the actual hdd from within it, connect it directly inside a desktop pc and attempt to access it from there.
If it fails even then the defect is in the controller of the hdd itself - the disk is dead, the data is lost.
Jul 01, 2011 | Computers & Internet
This drive has failed electrically. Needs EPROM board. Any ideas
Replace the drive.
Some of the portable drives can be removed and placed into another enclosure. That is another route to explore especially if you need to retrieve data from it.
Aug 31, 2010 | Toshiba 200GB USB 2.0 5400Rpm Portable...
I have a Lacie external HD 500G which we installed approx. one year ago. It was working great . However recently the mother board in our computer failed and was replaced with a new m-board. Essentially we...
Kevin, Yes you will loose al data if you format it.DO NOT FORMAT as you have your data on it. What I suggest is to get the motherboard of same old model that you replaced. Sometimes the motherboards do not play up with all the hardware. Get the same model motherboard that you replaced. Once that works, copy all data to some other HDD. Or better still send the data in bits by email to yourself. The data would be safe on the email server. And can be retrieved later when all is well. OR attach the drive to some other computer where it works and send emails to yourself. Long and tedious job, but will save your data. And when the drive has started working with your new computer after formatting or otherwise, you can retrieve all the data. and delete the emails from the server.
Nov 16, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Retrieving photos from memory card
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Dec 12, 2008 | Nokia N70 Cellular Phone
Can i retrieve deleted text messages from the sim card of a sanyo scp-7050
Thanks
Oct 07, 2008 | Sanyo SCP-7050 Cellular Phone
Flash Drive Crushed - Data Recovery
http://www.ontrackdatarecovery.com/
There is no way to retrieve data if your flash drive is broken but you can surely try it on other system and check.
But if it does not work then the only way to retrieve data ( if it is very important ) is to contact the website mentioned above and they will do it for you
Jun 08, 2008 | Computers & Internet
Western Digital Caviar WD2500JB Special Edition 250 GB Hard Drive Logo
203 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
