Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Lights do not go on, freezer fan does not work
  • 15,935 Answers
It is likely your door switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
The Sub Zero bottom dram freezer has stopped working
HI,
What does you freezer do? Does the lights work and fan work? The fan works with the cold control, if the light switch fails the unit will defrost in about 3 - 4 hours, will remain cold though, just not frozen. I need more information to direct you correctly.
I am here to help
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
The light on the front of my upright freezer is mot working and the inside of the freezer seems warmer. How do I fix this?
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.you also may want to remove the light bulbs, they are a great heat generator . freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Freezer and fridge sections both not working Light remains constantly on
From your description you have a bad fan/light switch. Light stays on and fan will not run, hence the warm refrigerator/freezer.
Apr 26, 2009 | Freezers
E521T
close freezer door, open fridge door and press the mode button
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Red light on
have you checked if the fan is running in the freezer??
if not, check if fan connected to defrost thermostat, if it is suspect defective defrost thermostat but try the fan directly if it doesn't go on, suspect bad freezer f
Apr 20, 2008 | Freezers
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
135 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
