Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
My Kenmore built-in dishwasher is running its cycles normally, but no water is coming into the machine so it runs the cycles dry (even a rinse cycle). Can you advise? If a part is needed, is it an expensive one? Thank you!!
  • 15,935 Answers
Sound like the inlet water valve is to blame here - or else the main controller board relay is not telling it to open. Further testing will be necessary to determine which is the cause.
If it is the board - you are better off getting a new machine.
The valve can be had for around $25.
go to repairclinic.com and enter in your exact model number for replacement parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
Testimonial: "I am delighted to have advice so quickly (within one day, and on a holiday weekend even), and insight into the problem. Thank you!!"
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
My Kenmore dishwasher will wash okay but, will not rinse. It runs during the rinse cycle but, no water comes in during cycle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwasher takes hours to run through wash and dry cycle. what should normal cycle time be?
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
Sep 13, 2009 | Kenmore Dishwashers
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch SHU430UC/06
ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
411 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
