Question about Kenmore 22422 Top Load Washer
Have a Kenmore Oasis 27032 Top loader washing Machine , works fine in all cycles but I'm not used to the rattling noise when Machine shifts over to the Spin cycle.The noise lasts for about a minute or more, I suppose as the Spin comes up to speed. Is this normal? If not, what do I need to do ? Nice Machine with great capacity, but the rattles are a bit discomfitting. Washer came with this house I recently purchased and also, I have Mechanical ability if this is a DIY project. Hints and assistance welcomed. Thanks from Ron
  • Kenmore Master
  • 19,396 Answers
Hi.
The rattling noise is usually caused by object held in the drain pump trap. You hear the noise when spinning because before and during spinning the machine drains water.
If the noise was caused by the speed you would hear noise from drum bearing, from gearbox, or from drum rotation, but in that case it would not be a rattle, but banging or loud high pitched noise.
Accessing the drain pump on this washer is not as easy as on a top load, the pump is located at the base of the washer. Here a diagram with instructions.
Posted on Sep 05, 2010
Makes a rattling noise inside like coins are stuck in it. Does this on the last spin cycle. Never find any money inside the drum though?
Having some trouble using this webiste. I have the exact same problem with my Kenmore Oasis top-load washer. Were you able to find a solution?
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
LOUD RATTLING NOISES ON SPIN CYCLE (SOUNDS LIKE MONEY OR MARBLES IN MACHINE)
you'll need to investigate further. It may even mean bringing in a professional to be sure the vibration damper rods are ok - to prevent future and costlier problems.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Spin Cyle Extremely Loud
Your probably right as most washing machines use bearings and they do wear out rather quickly on some machines ,depending on how yours was put together will determine on how easy it is to change , some manufactures made it much more easy than others .If you remove the back panel (that's if it has one )and after it has gone through its spin cycle and you have turned of the power you should be able to feel around where the bearing is incased to see if it has generated an amount of heat even though they are usually encased in oil as this would be a indication that it has failed, if you watch the machine clicking into spin mode ( by looking at the motor etc with the back cover removed)you will also get a better idea as to what parts have come into play and pinpoint the problem area .
Aug 07, 2017 | Kenmore 27032
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22422 Top Load Washer Logo
155 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
