Question about Car Audio & Video
I have a seat Altea 54 reg, the radio/cd keeps switching itself on when parked up and the ignition turned off and key removed
Hi did you sort your problem as i have the same problem with mine!!! but the dealer says he cannot find a fault.
Posted on Sep 21, 2010
I have a Seat Altea and need to know if I will encounter any CPU or alarm problems if I remove the factory fitted Blaupunkt radio entirely from the vehicle?
Radio's don't affect the security. But if installing another factory radio, it has to be programmed to your car. After market radios don't. If using an after market one, you will loose some chimes, like door,key,lights, ect...
Sep 03, 2016 | 2008 Seat Altea 2.0
A few hours ago I turned the ignition key to the position that allowed me to remove a CD from the radio, and I must have left the key in that position. Now it seems like the battery has drained down to...
that is strange that the key will not release -- there is nothing electrical about the key being held in place. I would recommend trying to move the steering wheel back and forth as you try and turn the key/ignition back and forth and then back to off and try and get the key out then. if this does not do it then it sounds like something has gone wrong in the ignition switch itself and I would recommend jump starting the car and driving it down to your local automotive locksmith and see if they can get the key to release. the ignition might need to be re-pined and a locksmith can do this for you and get your key working good again.
hope it all works out,
c...
Jan 01, 2011 | 2007 Cadillac DTS Sedan
How do I change the ignition switch in my 93 plymouth van?
FIRST OF ALL, TURN OFF RADIO,DISCONNECT NEGATIVE BATTERY CABLE. IF EQUIPPED WITH TILT STEERING COLUMN,REMOVE TILT LEVER.CAREFULLY REMOVE THE UPPER AND LOWER STEERING COLUMN COVERS. REMOVE THE 3 TAMPER PROOF TORX IGNITION SWITCH MOUNTING SCREWS USING SNAP ON TOOL TTXR15A2 OR EQUIVALENT. GENTLY PULL THE SWITCH AWAY FROM THE COLUMN AND REMOVE THE 2 ELECTRICAL CONNECTORS FROM THE IGNITION SWITCH. WITH THE KEY IN THE LOCK POSITION, DEPRESS THE KEY CYLINDER RETAINING PIN FLUSH WITH THE KEY CYLINDER SURFACE. ROTATE THE KEY CLOCKWISE TO THE OFF POSITION THE KEY CYLINDER SHOULD NOW BE UNSEATED. ROTATE THE KEY CYLINDER COUNTER CLOCKWISE BACK TO THE LOCK POSITION, AND REMOVE THE LOCK CYLINDER. ( TO INSTALL ) CONNECT THE ELECTRICAL CONNECTORS TO THE IGNITION SWITCH. BE SURE THE CONNECTORS ARE SECURELY LOCKED IN PLACE. MOUNT THE IGNITION SWITCH TO THE COLUMN 3 SCREWS FOR VECHICLES WITH THE TILT STEERING COLUMN THE SHIFTER MUST BE IN THE PARK POSITION AND THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG MUST BE INDEXED BEFORE THE SWITCH IS INSTALLED. PLACE SHIFTER IN THE PARK POSITION. PLACE THE IGNITION SWITCH IN THE LOCK POSITION. THE SWITCH IS IN THE LOCK POSITION WHEN THE STEERING COLUMN LOCK FLAG IS PARALLEL TO THE IGNITION SWITCH TERMINALS. POSITION THE PARK LOCK DOWEL PIN OF THE IGNITION SWITCH SO IT ENGAGES THE STEERING COLUMN PARK LOCK SLIDER LINKAGE. APPLY A LIGHT COATING OF GREASE TO THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG. POSITION THE IGNITION SWITCH AGAINST THE LOCK HOUSING OPENING ON THE STEERING COLUMN. BE SURE THE SWITCH PARK LOCK DOWEL PIN ENTERS THE SLOT IN THE PARK LOCK SLIDER LINKAGE INSTALL THE RETAINING SCREW AND BRACKET. TORQUE THE SCREW TO 26 INCH LBS. INSTALL THE STEERING COLUMN COVERS AND THE TILT LEVER IF REMOVED. WITH THE KEY CYLINDER AND THE IGNITION IN THE LOCK POSITION INSTALL THE KEY CYLINDER INTO THE SWITCH UNTIL IT BOTTOMS. RECONNECT THE NEGATIVE BATTERY CABLE AND THE CHECK THE IGNITION SWITCH FOR PROPER OPERATION OF HALO LIGHT SHIFT LOCK IF EQUIPPED AND COLUMN LOCK.ALSO CHECK FOR PROPER OPERATION OF THE IGNITION SWITCH ACCESSORY, LOCK OFF, RUN AND START FUNCTIONS.
Sep 18, 2010 | 1993 Plymouth Voyager
Unable to remove key from ignition 2002 Pontiac Grand Prix
The ignition has an interlock that will not let you turn the key all the way to OFF until the transmission is in park.
This is done via a sensor either in the transmission itself, or on the shifter.
With the car off, step on the brake and shift from Park to Reverse, then back in to Park. You should hear a faint "click" as the interlock engages. If not, then your sensor (switch) may have failed.
Apr 17, 2010 | 2002 Pontiac Grand Prix
I have a mark 3, Y reg seat ibiza 1.4s,with an array of wierd electical problems. the radio keeps turning itself on, even when the car's ignition is off, the keys out, and the doors locked. It flattened my...
Ive got the radio problem, having to remove the radio fuse each time I get out of the car - its the blue 15amp on the top row of the fuse board. As for fixing it, heard its either down to the radio switch or diode? Taking mine to garage though.
Jan 09, 2010 | 2001 Volkswagen Golf
1991 Dodge Spirit ignition problem
The "SPRING-BACK" Action is Originated in the Ignition Switch itself (THE ELECTRICAL SWITCH) I think that is where you should Look. On these models, the ignition lock and ignition switch are removed as an assembly. Refer to IGNITION LOCK .
Disable airbag, refer to Air Bags and Seat Belts/Air Bags (Supplemental Restraint Systems)/Service and Repair . After procedure has been completed, rearm airbag system.
  1. Disconnect battery ground cable.
  2. Remove tilt lever.
  3. Remove three Torx column cover attaching screws, then the upper and lower column covers.
  4. Using tamper proof Torx bit tool No. 440-TX20H or equivalent, remove three ignition switch mounting screws.
  5. Carefully pull switch away from column. Release two connector locks on seven terminal wiring connector, then disconnect from ignition switch.
  6. Release connector lock on four terminal connector, then disconnect from ignition switch.
  7. Remove ignition lock from ignition switch as follows:
    1. With key inserted and switch in Lock position, use a small screwdriver to depress ignition lock retaining pin flush with lock cylinder surface.
    2. Rotate key clockwise to Off position. Ignition lock should now be unseated from ignition switch assembly. Do not attempt to remove ignition lock at this time.
    3. With ignition lock in unseated position (lock bezel approximately 1/8 inch above halo light ring), rotate key counterclockwise to Lock position, then remove key.
    4. Remove ignition lock from ignition switch.
  1. Reverse procedure to install, noting the following:
    1. Connect two wiring connectors to ignition switch. Ensure switch locking tabs are fully seated in connectors.
    2. Install ignition switch on steering column.
    3. On column shift models, shift lever must be in P position and park lock dowel pin on ignition switch assembly must engage with column park lock slider linkage.
    4. On all models, verify ignition switch is in Lock position (flag parallel with ignition switch terminals).
    5. Apply a dab of suitable grease to flag and pin, then position park lock link and slider to mid-travel.
    6. Position ignition switch against lock housing face. Ensure pin is inserted into park link contour slot.
    7. Install ignition switch retaining screws and torque to 12-22 lb-in .
    8. With ignition lock and switch in Lock position, insert ignition lock into ignition switch until it bottoms.
    9. Insert key, then while carefully pushing ignition lock toward ignition switch, turn key clockwise to Run position.
    10. Check for proper operation on ignition switch in all positions.
FOR PICTURES EMAIL ME AT MY NICKNAME HERE ON FIXYA @AOL.COM
Feb 12, 2009 | 1991 Dodge Spirit
The radio is turning itself on when car is locked up
you bought a daewoo - thats your problem, theyre ****- solution, roll it off a cliff
Dec 30, 2008 | 2001 Daewoo Lanos
Golf 54 plate mk v radio turning on
Volkwagen UK's official response, October 6th 2008: keep a music CD in the slot. Which has to be better than paying nearly £600 to replace the radio.
Let's hope it works!
Jul 03, 2008 | 2004 Volkswagen Golf
Car Audio & Video Logo
314 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
