Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the oil mixture for husqvarna chain model 235
    Brigadier General:
  • 4,088 Answers
50:1 fuel to oil ratio is correct for this saw. Be sure to use modern synthetic saw oil, not a petroleum product like outboard motor oil. Premix the fuel and oil in it's own can, and shake thoroughly just before filling the saw each time. With these modern fuel/oil ratios, serious engine damage can occur if not thoroughly mixed each time. Hope this helps!
Posted on Sep 05, 2010
I need to know the correct fuel ratio for a Huska Vona 235 chainsaw
50:1. Your manual is here.
[PDF]OM, 235 e/ 240 e, 2008-02, Chain Saw - Husqvarna www.husqvarna.com/.../HUSO%2FHUSO2008_USen%2FHUSO2008_USen_O08020...
  1. Cached
235e 240e. Operator's manual .... You will find the following labels on your chain saw: ..... recommended (a lean mixture may mean that the fuel lasts longer than ...
http://www.husqvarna.com%2Fddocdownload%2FHUSO%252FHUSO2008_USen%252FHUSO2008_USen_O0802031_.pdf&usg=AFQjCNHmUdP3dUYTbfqmTs7Z7SATwGd1Nw
Jan 23, 2017 | Garden
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
What is the longest bar &chain i can put on my husqvarna 235
if you tighten the panel for the bar and chain too tight it pulls the bolts out slightly out of the chassis of the body. that is why it isnt oiling properly. i had a 235 and that is what happened to mine. what you could do is file down the raised plastic where the bolts enter the body and that might help.
Apr 17, 2012 | Husqvarna Garden
Husqvarna 235 - not oiling- pulled oiler out checked oil flow from tank all OK. Assembled oil pump with inlet line full of oil and ran pump with coreless drill in both directions and no oil flow checked...
You cannot just rotate the pump shaft and expect it to pump, it has to have a throw, this is done by an acentric groove in the nylon pump gear working on a steel pin in the pump cover, the bigger the throw the more oil is pumped, the biggest problem with the early model was the oil went down the side of the bar and not onto the chain, there was a later delivery/pick up pipe to solve this.
Jul 05, 2011 | Husqvarna Garden
My 235 won't oil chain
This model had many issues with oiling, there was a later reto fittable oil delivery tube to help this part no. 545227501.
Jul 03, 2011 | Husqvarna 16" Chainsaw Chain Saw Bar...
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
543 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
