Question about Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
How do you wire it ? - Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro
Need wiring diagram for stereo or wire color coding
1997 Chrysler Sebring Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Black/Yellow
Radio Illumination Dimmer Wire: Green/Yellow
Left Front Speaker Wire (+): White/Blue
Left Front Speaker Wire (-): Black/Blue
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Black/Red
Left Rear Speaker Wire (+): Yellow/Blue
Left Rear Speaker Wire (-): Gray/Blue
Right Rear Speaker Wire (+): Yellow/Red
Right Rear Speaker Wire (-): Gray/Red
Nov 08, 2012 | 1997 Chrysler Sebring
Color code wiring for radio
1996 Chevrolet Suburban Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Oct 11, 2012 | 1996 Chevrolet Suburban
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
I replaced the ignition switch in my 1995 ford ranger now the alarm won't stop
95 Ford Ranger Auto Alarm Wiring Diagram.
You need to re-check your ignition wiring. Here is the wiring for the alarm.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): White/Black Or Brown
Parking Light Positive Wire Location: At Headlight Switch Or Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Pink/Yellow (Type B)
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (Type B)
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire With A Tan Stripe Or A Yellow Stripe
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: Low In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 16, 2011 | 1995 Ford Ranger Supercab
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
Trying to hook up a new stereo. Where can i find a wiring schematic for a 1994 toyota pickup?
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Hope this helps
Dec 10, 2009 | 1994 Toyota Pickup
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Starter Positive Wire (+): Black
Ignition Positive Wire (+): Black/Yellow
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Accessory Positive Wire (+): Blue/Red
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Horn Negative Wire (-): Green/Red
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Dark Blue
Accessory Positive Wire (+): Black/Orange
Parking Light Positive Wire (+): Black/Yellow
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
Intermatic T103 Indoor 120-Volt 40-amp Timer Switch-Double Pole/Single Thro Logo
81 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
