Question about Insignia I-LC23Q1 23 in. HD-Ready LCD Television
I bought an ac power cord (the three prong type not the three prong flat but round prongs) and my tv will not turn on. Im not sure if its this generic cord (it wasnt specifically for the tv) or its the tv itself. My question is, are there ac cords that are different from others or are they all the same? Product is Insignia i-lc23q1 tv p.s. Went everywhere to get a 2nd cord no one has it (Best buy, radioshack, pc richardson, etc...)
SOURCE: Insignia Flat Screen TV - no cable signal
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
Posted on Dec 10, 2007
SOURCE: Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Posted on Mar 14, 2008
  • 80 Answers
SOURCE: insignia 15 inch lcd tv cant find replace power cord
part # 485-10144-00
try or
neither have it but there you go
Posted on May 30, 2008
SOURCE: Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
Posted on Aug 28, 2009
  • 312 Answers
SOURCE: insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Posted on Oct 01, 2009
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
Jan 17, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Got a monitor from a frieng. No electrical plug. What does it look like and where does it go?
Denise, If you own a PC, and the monitor is NOT a Flat panel, odds are good it is the same three pronged cord that fit's your PC's power supply. If it IS a flat panel display, then it may STILL take that same three pronged cord, OR it may require a specific AC adapter. Do you have a model number?
Aug 10, 2012 | Computers & Internet
I have a customer that lost his power cord. Where can one be purchased? Thank you Jenny Followell
Tries websites like,, to buy the LCD tvs power cords.
Sep 01, 2010 | Mintek DTV-373-D 37 in. LCD HDTV
Gets dark wave in three waves,
The first thing I would suspect is a noisy AC supply. Try using a ground adaptor. Sounds technical, but if you every went to Grandpa's he may have been using a few and you just didn't know what they were. They are commonly used to adapt a 3 prong electrical plug to a 2 prong AC outlet. If your TV does have a 3 prong AC cord, give this a try before you do anything. It's a cheap solution and often works like a charm.
Mar 17, 2010 | Vizio Televison & Video
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Jun 08, 2009 | Electrolux Dryers
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
Insignia I-LC23Q1 23 in. HD-Ready LCD Television Logo
42 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
