Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Remote ceiling fan spin slow - Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
  • 7 Answers
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
Buy a speed control with a reversing switch.
Posted on Jun 29, 2009
  • 45 Answers
SOURCE: Power went out and now ceiling fan won't work
It is quite likely that the unit has an internal surge supressor/fuse that blew when the power went out. Tou will need to open the housing to the fan motor and inspect the fuse. Once you get the fan working, the remote will work just fine.
If the problem is the remote itself, then it is possible, though highly unlikely that the remote code has been wiped out that connects the remote with the receiver on the main unit. If so, hopefully there are reset/reprogramming instructions in the manual.
Posted on Sep 07, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
  • 91 Answers
SOURCE: Ceiling fan will not spin fast
in england the usual house current is 220 volts and here the current is 120volts. this explains the problem. unless there is a switch to change your fan to a 110 current built in it might make sense to buy a new fan and move on. rewiring it would be expensive and unless it has alot of sentimental value probably not worth it.
Posted on May 31, 2010
Testimonial: "Arsehole"
  • 351 Answers
SOURCE: the ceiling fan spin was slow. The c61 e185116
Hampton Bay is an exclusive brand to Home Depot. They have replacement parts for these fans. They are usually in the lighing / ceiling fan section. The end cap that has fan parts and lighting accessories.
Posted on Jun 23, 2010
Ceiling fan MY143 speed are unable to be control by remote control and spin very slow
Lube the bearings after washing them out with contact cleaner. Sometimes the grease hardens and is very rubbery feeling
Mar 04, 2016 | Dryers
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Why my selling fan does not spin faster?
It is a speed switch issue you will need an electrician to come in and repair or replace the switch for your ceiling fan as I had the exact same issue last summer with my ceiling fans. I hope this helps.
Sep 03, 2012 | Computers & Internet
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
The ceiling fan spin was slow. The c61 e185116
Hi, replacement capacitor can be found at amazon. Take a look here: Amazon com c61 capacitor 4 wire. I hope this was helpful. cheers
Jun 22, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
My ceiling fan isnt working right
dont you have a three position pull switch on the unit like a three-way light bulb or if you have a remote controlled fan it should have it on the remote control
Sep 24, 2009 | Encon Industries (78018) Ceiling Fan
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
New Hampton Bay ceiling fans spin too slow
Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
