Question about Weber Genesis E-310 Gas Grill
I have a new Weber Genesis E-310 Liquid Propane Gas Grill I have used just once and today I replaced the propane twice and still can't smell the gas and start the grill.
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 06, 2010
Testimonial: "Thanks for the great hint. This solved my problem."
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
How do I use the gas gauge on my genesis grill?
If it's like mine, you literally hang the propane tank on a hook. The gauge is basically a spring and as the propane is used and lightens the tank, the spring contracts.
May 02, 2012 | Weber Genesis E-310 Gas Grill
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
I'm trying to start grill, it has a full propane tank , it ignites then it turns off
You might have a bad propane tank. If the tank is new take it back and tell them you think the valve is bad. They should exchange it free of charge. Sometimes the valves on the tanks go bad, then they just don't get very much gas and can easily shut off.
Jun 06, 2011 | Weber Genesis E-310 Gas Grill
I have a new PinnacleTG560N natural gas BBQ and I want to convert it to propane, what can I do, or can I get a converion kit to make this work.
Unfortunately, there's nothing you can do. According to Weber, there are no conversion kits, as your grill is not convertible to propane. Like wise, a Weber propane grill is not convertible to natural gas.
Link to your Owners Manual (see page 2 - Warnings):
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Apr 28, 2011 | Weber Spirit? E-310 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Genesis GE310 Gas Grill: I just installed a full propane tank on my Weber, ...
Maybe just clearing air out of the line, other than a minute would not be normal.
May 18, 2010 | Weber Genesis GE310 Gas Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Weber EP-310 Gas Issues
Hi Amir
Did you ever get an answer to your issue? I am also curious if I can bring my Weber to Israel...
Dec 05, 2007 | Weber Genesis Silver A Grill
Weber Genesis E-310 Gas Grill Logo
1,348 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
