Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Spray arms are not moving - GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
  • GE Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 07, 2010
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
The top washer is not spinning
Look at the top spray arm and see if it moves freely. Inspect the middle part of the spray arm. Sometimes a tall dishes can prevent the arm from moving. Put the spray arm at 12 o'clock position and have a cup right side up in the dishwasher. Run a cycle. During the cycle the cup should be filled to the top with in 20sec and the spray arm should have moved from its position. If not then change out the spray arm and Delivery tube.
Thanks, Please rate your experience
Dec 11, 2010 | KitchenAid Dishwashers
My dishwasher sprays water up into the dishes but the little spray arms don't move when the water sprays up. The arms move by hand when I touch them. What could this mean for my dishwasher?
heatman101
Aug 31, 2010 | Whirlpool Dishwashers
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Sep 22, 2009 | Dishwashers
Equator PLS600 spray arm will not move.
Problem solved. Removed spray arm assy including nut (attached to body). Manually moved propeller inside water inlet. This freed it up enough to get her working again. Apparent cause was enough debris in chamber to cause it to seize. Note that this fix was preceded by the famous WikiFix of filling chamber with baking soda then topping it off with white vinegar, left overnight. Also note that the above manual movement of the propeller was done with the machine on (not recommended) at the point in the cycle where the spray arm should have been operating.
Jun 25, 2009 | Equator 20 in. PLS600 Free-Standing...
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Upper arm does not spin
No I don't believe its the pump. I believe the lower spray arm is possibly split open on the side causing a loss of presure and flow to the upper arm and overloading the door seal. As well the loss of flow to the upper arm will resulted in it turning too slow.
Aug 12, 2006 | Frigidaire 24 in. FDB635RF Built-in...
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
114 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
