Question about Gateway FPD2275W LCD Monitor
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
  1. After 30 minutes it turns off for a second and then back on 2-3 minutes later it does it again, then faster and faster as it warms more & more.
  2. It seems only when it gets hot, it's not in the first 30 minutes of using it.
  • Dannysialina May 12, 2008
    LCD is 4 Yrs. old was new when purchased.
    I was told the the INVERTER could be the problem and to get it changed.
    Any help will be appreciated
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
Posted on May 12, 2008
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
Samsung Monitor 192N light turns green when powered on then goes out after few seconds
this usually means the monitor is not getting a signal
  • i would check the hdmi/dvi/vga cable connections dirk_s.jpg
    both on the back of the pc and on the back of the monitor.
  • if the connections are tight, and plugged in well, maybe try and connect it to a second computer or laptop.
    • If it works the problem probably lies with your gfx card in your computer (verify this by trying another monitor on it)
  • If it doesn't work on those i would try and replace the aforementioned cable (usually pretty cheap)
  • if the problem still persists the monitor would probably need to be replaced as its defective.
Feb 28, 2011 | Samsung Syncmaster 192N 19" LCD Monitor
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Whenever i try to turn my Samsung Gravity off, to seconds later it turns itself back on again. How do I fix this?
Take out battery for 30 min. Or you can leave the battery to be emptied and phone will switch itself. Don't turn on just plug in charger.
Sep 20, 2009 | Samsung Gravity SGH-T459 Cell Phone
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Samsung 192N suspect power supply problem
I'm sure it is power board failure that need repiar or replaced the defectieve parts of your LCD .
Apr 18, 2008 | Samsung Syncmaster 192N 19" LCD Monitor
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Toshiba plasma tv 42hp94 works good for 20 to 30 minuts and then the screen starts flikering and the pictures go black. once i put a fan behind it the picutes come back ok and tv works good. what could be...
My 42hp83 will only stay on for 30 seconds and then turns off. Repair service came to the house today 2/27/08 and said they could do nothing with it. I think I'll get a second opinion.
Oct 31, 2007 | Toshiba 42HP95 Television
Gateway FPD2275W LCD Monitor Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
