Question about Nikon D90 Digital Camera with 18-105mm lens
Hi I am getting an erro message "r33" in the "number of exposures remaining box" - when the message comes up I cannot take a photo - its like the camera is locked. any ideas? also, sometimes the r33 message comes up and it does let me take the picture. so maybe the camera locking issue is not related top the r33 message? Lance
  • 567 Answers
The r33 that you see on the top panel of the camera is the count of shots remaining to fill the buffer in burst mode.
Looks like you must be set on jpeg.
Do you format the card regularly in camera?
This looks like an issue with camera having issues reading the SD card on start-up.
Please try to format the card and check again if the issue persists.
If you have another SD card, please try to use that one and see how the camera behaves.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Posted on Sep 11, 2010
  • justmeelp Jul 25, 2011
    I had same problem and asked around and this was what I got to fix it:
    I started thinking in the middle of the night that I should tell you what Rodney had me do.
    Copy all pics on card to PC
    Try to format the card but that didn't work so he had me hold down the trash can button and mode button until FOR appeared on the display and hit those buttons again. Card formatted, problem gone.
Out of memory message after 3 photos on new memory card
Hi Bob,
Your camera has two memories. It has a 23 Mb internal memory in addition to the SD add-on memory. If you look on page 30 of the Reference Section of your camera's manual Number of Exposures Remaining table (link below), you will see that when set at the highest resolution, your camera will only allow three exposures in the 23 Mb memory. I would go into your camera's menu and make sure that you have set it to use the SD card instead of the internal memory. You may also want to take lower resolution pictures to increase the number of pictures you can fit in memory. Also, make sure that once you do that, you reformat your SD card in the camera, not on the computer.
http://download3.nikonimglib.com/archive1/nnTgc00N0x4q00P2lCs46LoqNp55/S9500S9400RM_(En)06.pdf
Mar 12, 2014 | Nikon Coolpix S9400
Over exposed photos
Your exposure compensation might not be set correctly. Just behind and to the right of the on/off switch you will see a small button with a "+/-" symbol. That is the exposure compensation switch. When you press it, you will see a number displayed on the LCD. If the number is positive, that is your problem. Positive numbers increase exposure and negative numbers decrease exposure. Set the compensation to 0.0 by turning the rear thumbwheel while depressing the exposure compensation button.
Jan 09, 2014 | Nikon D90 Digital Camera with 18-105mm...
"error code" r33
Is this keeping you from shooting? Normally this is an informational message telling you how many more shots you can take in the current burst before the buffer fills up and the camera has to stop shooting and write to the memory card.
Sep 09, 2013 | Nikon D90 Digital Camera with 18-105mm...
We are trying to set up some product photos with a white background and 2 x 1000W soft boxes The background is coming out grey not white How do we set up to give us a bright white background and clear...
1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken •
Jan 31, 2011 | Olympus SP-500 UZ Digital Camera
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Photos taken inside are fuzzy
i think the exposure settings have changed and set to hi if you can get the exposure setting to normal [+/-] to 0 or the shutter has been set to low or the iso has been set to low
but if u are skeptic about going to settings and changing those all important combinations then safest way is to restoring to factory defaults and from there u can keep experimenting again
if there is anything else that you would like to know u can mail me at mail2pvs@gmail.com
happy clicking
Jul 14, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Error message r07 on D80
his isn't an error message. R04 or R07 or R[any number] refers to the number of shots you can take before you're camera's internal memory buffer is full.
As you're taking pictures, you're camera is writing to your memory card. When you are taking burst photographs, all the other photos you've just taken are "waiting in line" to get written to your card. If your buffer is full, the camera will not let you take another shot until it's finished writing the photo to the card.
Your camera's ability to write to the memory card is only as fast as the memory card itself as well as the quality of the photos (RAW vs. JPEG).
Sports photographers usually shoot in JPEG because they are taking a lot of shots relatively quickly and if their camera freezes then they can lose a shot.
the R means remaining, so R03 three shots remaining/left before the buffer is full.
Switching off the NR high iso and long exposure. buying a 166x card or faster will help but you won't see it on the counter.
If you do the above and switch to jpeg only it goes up.
you won't do this but, the above and quality to basic and small gives R51.
But if you shoot raw its R06 at best.
Any further help, let me know.
Jun 16, 2009 | Nikon D50 Digital Camera
Black picture the lamp does't lit. no error message.
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
May 29, 2009 | Canon Office Equipment & Supplies
Nikon D90 Digital Camera with 18-105mm lens Logo
892 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
