Question about Video Game Consoles & Games
I got a wii and i think somethings missing i would like to know everyting a standard wii console come with.
    President:
  • 1,139 Answers
Ok, a standard Wii console should come with the following :-
The Wii console
A clear plastic console stand
Sensor Bar
Small clear plastic sensor bar stand
1 Wii remote
1 Wii nunchuck
1 power adaptor
1 composite AV cable
1 Scart adaptor
2 x AA batteries
Operating Instructions
Wii sports game
Hope this helps and thank you for using fixya
Posted on Sep 05, 2010
Testimonial: "it was very helpful in getting info"
Loaded a new game, "NBA2K13" in an older wii and it had to Upgrade the system, which it did successfully. But the game would never load and now my old games wont work. When I load wii Sports, the icon for...
I'm thinking that this may be a coincidence.
Do you know if the older Wii was even reading games before you put NBA2K13 into it???
Usually when a Wii isn't reading games, the DVD drive or the laser inside of it has failed. The eventually wear out on all of the gaming consoles (I don't think lasers were means to be worked so hard). You can find a replacement Wii drive at the following page:
Jan 09, 2014 | Nintendo Wii Console
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Lost communications to WII remotes and board
hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
Apr 20, 2010 | Nintendo Wii Console
My Wii console still runs after I turn it off.
As long as the unit is plugged in, then the red light will still be there, that is just how the console works.
If you mean that it is spinning the disc, then I can't help you. If it really annoys you take out the disc after your done, and then it shouldn't spin. Unless I'm missing something that you need to specify, that's the only thing I can think of.
Sep 27, 2009 | Nintendo Wii Console
Mine either
you need a new 1 if it has gotten wet or it has been dropped. bring ur old 1 2 the store and they MIGHT replace it 4 free
Jun 16, 2009 | Nintendo Wii Console
Wii Menu doesn't start up!
i think you just bricked that wii dude
i think there are ways yo unbrick it but i think they all require a bit more than the average user is capable of...
Feb 12, 2009 | Nintendo Wii Console
I think that my little brother put something inside wii console
The mechanism that accepts disk is faulty probably due to something being forced into slot. Have fixed many problems the same as this. If you need me to have a look let me know lindop@hotmail.com. NO FIX, NO FEE returned free of charge
Feb 01, 2009 | Nintendo Wii Console
Europran wii
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
  1. Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
  2. European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
  3. European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
  1. You need to get games from France (or at least Europe)
    You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
  2. You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
  3. Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores.
    If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
Hope that helps...
Apr 02, 2008 | Nintendo Wii Console
Wii controller gloves
Ask Nintendo. I personally have never heard about getting these sleeves for free, I think that you may just have to buy them.
Mar 14, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
