Question about Tasco Optics
I have a 49114500 and at the rear mirror area, there are three manual adjustment screws. When I remove the large front cover, I notice that the mirror is not centered on the front 'three sectonal' scope unit (?). Are the three adjustment screws in the rear used to center the 'three sectional' device to the mirror? How? Thank you in advance...
  • 3,186 Answers
Those are the PRIMARY MIRROR collimation screws. Watch this video:
http://www.andysshotglass.com/Collimating.html
Posted on Sep 06, 2010
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
CAN I CLEAN THE MIRROR ON MY HTACHI 43FDXOIB TV
With the set unplugged remove the back cover of the set.
Next remove all the screws on the entire large plastic shroud that is black in color; you will notice hand holds to lift it free and the mirror is attached to the inner side.
l usually use paper towels and glass cleaner to clean it and also clean the three large black plastic lens in front of it. It either is dirty or grimy the picture will be affected.
Carefully replace the mirror/shroud unit and put all the screws back that secure it.
Replace the back cover and see what it looks like. There is no access from the front of the set to do this.
SD TECH
May 09, 2010 | Hitachi Televison & Video
How do i replace left door mirior
remove trim panel, remove mirror fasteners.
Glass, Outside Mirror—Town Car
  1. Push upper edge of outside rear view mirror glass (17K707) into the outside rear view mirror to expose latch release.
  1. Using a small flat-bladed screw driver or equivalent, move latch release to released position.
  1. Remove outside rear view mirror glass mounting back and outside rear view mirror glass from outside rear view mirror.
  1. Disconnect heater wire connectors and auto dimmer connector, if equipped.
  1. To install reverse Removal procedure.
Mirror, Power—Outside Rear View
Town Car
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove front door trim panel (23942). Refer to Section 01-05 .
Trim Panels, Door Front—Town Car
Removal
  1. Snap out two door pull strap retaining screw covers. Remove screws.
  1. Remove three screws on front and rear side and center of front door trim panel (23942).
  1. NOTE: The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
    Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
  1. NOTE: Do not use front door trim panel to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
    Remove window regulator control switch housing from front door trim panel. Lift up housing in front and disconnect all connectors.
  1. Disconnect wiring harness and heated seat switch electrical connectors if equipped.
  1. Remove the door trim panel.
  1. Disconnect two electrical connectors.
  1. Remove nut from outside rear view mirror mounting base.
  1. Swing outside rear view mirror (17682) toward driver door window glass to expose screw in mount base.
  1. Remove screw from outside rear view mirror base.
  1. Remove outside rear view mirror from front door (20124). Guide wiring and connectors through hole in front door.
  1. To install, reverse Removal procedure. Tighten nuts to 8-10 Nm (71-88 lb-
Nov 05, 2009 | 1996 Lincoln Town Car
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Need instructions to replace drivers side rear view mirror glass.
Outside Mirrors REMOVAL & INSTALLATION The mirrors on these models can be removed from the door without disassembling the door liner or other components. Both left and right outside mirrors may be either manual, manual remote (small lever on the inside to adjust the mirror) or electric remote. If the mirror glass is damaged, replacements may be available through your dealer or a reputable glass shop in your area. If the plastic housing is damaged or cracked, the entire unit will need to be replaced. Manual
  1. Remove the set screw and the adjustment knob, if equipped.
  2. Remove the delta cover; that's the triangular black inner cover. It can be removed with a blunt plastic or wooden tool. Don't use a metal prytool; the plastic will be marred.
  3. Fig. 1: Use a tapped ended tool to pry the trim from the mirror 89550g29.gif
  4. Depending on the style of mirror, there may be concealment plugs or other minor parts under the delta cover — remove them.
  5. Support the mirror housing from the outside and remove the three bolts or nuts holding the mirror to the door.
  6. Remove the mirror assembly.
  7. Installation is the reverse of removal.
  8. Power
    1. Turn the ignition key to the OFF position. Disconnect the negative battery cable. Wait at least 90 seconds from the time the negative battery was disconnected to start work. CAUTION
      Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6.
  9. Depending on the style of mirror, there may be concealment plugs or other minor parts under the delta cover — remove them.
  10. Depending on the type of door trim, you may need to remove the door inner panel to access the electrical wiring harness for the mirror.
  11. Support the mirror housing from the outside and remove the three bolts or nuts holding the mirror to the door.
  12. If the wiring to the electric mirror was not disconnected previously, detach it now. Some connectors can only be reached after the mirror is free of the door. Remove the mirror assembly.
  13. Installation is the reverse of removal. Cycle the mirror several times to make sure that it works properly.
Jul 23, 2009 | 1996 Toyota Camry
Sideview mirror assembly removal
  1. Remove the front door trim panel (23942) ; refer to Section 501-05 .
    • Peel back the watershield.
  1. Remove the rear view mirror mounting hole cover (17K709).
  1. Disconnect the power mirror electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Remove the screws.
    1. Remove the outside rear view mirror.
please rate as fixya if this works for you.
Mar 03, 2009 | 1998 Ford Escort
Side View Electric mirror can't adjust up enough for my height
You can manually push the mirror left or righ or up and down. It just ratchets on the plastic screw adjusters. It won't do any damage.
If you have floding mirros, make sure they are locked into position.
here's what inside looks like of 2002 mirror. I don't have 2005
SECTION 501-09: Rear View Mirrors 2002 Taurus/Sable Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
All vehicles
  1. Remove the front door trim panel (23942). For additional information, refer to Section 501-05 .
Vehicles with Mach 40 speakers
  1. If equipped, remove the speaker grille.
  1. Remove the speaker bracket.
    • Disconnect the speaker electrical connector.
Vehicles with speaker delete panel
  1. Remove the speaker delete panel screw cover.
  1. Remove the speaker delete panel.
    1. Remove the panel.
All vehicles
  1. Disconnect the power exterior rear view mirror electrical connector.
  1. Position the water shield aside.
  1. Remove the power exterior rear view mirror nuts.
  1. Remove the power exterior rear view mirror.
    1. Push down on the mirror assembly to release the mirror flange.
    1. Roll the mirror assembly down and rearward.
Jan 21, 2009 | 2005 Ford Taurus
Picture is dark. I've consulted manual and tried suggestions
Is it dark even with the menu settings up high? Is it dark even in the menu settings? It could either be a dark signal input OR Dim light source. Depending on model, if it's LCD or DLP based, you probably need a new bulb. If it's CRT based, you can bring them back to life with a simple adjustment. If it's a CRT (depending on model) the adjustment is either on the back, or on the front behind the covers. There then will be a plastic adjusting screw. BE CAREFUL, there is high voltage back there. You want the TV on and with the menu settings of brightness and contrast all the way up for this part. With a second person there to help spot (if controls are on the back) bring the screen adjustment screw slowly up. Depending again on model, their might be one, their might be three that say screen. Adjust them up until a little brighter then desired but not past the horizontal retrace lines. Lot of information, but really it's an easy fix to get a few more years out of any tube tv that's worn and keep them out of the landfills.
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Optics Logo
135 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Bill Laudeman
Bill Laudeman
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
