The spray arm is connected to the pillar which is connected to the wash pump at the base. You will need to get a large spanner and turn it anti-clockwise holding the flat profile section of the pillar. I am assuming the spray arm pillar looks like this.
You could also have a coupler like this joining the pump to the pillar. So if the whole pillar and the coupler start moving together when you unscrew then you may have to hold the pump socket firm from the bottom of the dishwasher.
Best way to work this would be to empty the dishwasher and disconnect from supply and drop it on one side on the floor.
Hope this helps.
Hi.
Here a diagram for your model, click on the picture to enlarge:
we tried to turn the tower couonter clockwise and it just turns but doesn't come out?
we tried turning the tower counterclockwise and it just spins but doesn't come out. what now.?
O.K this is frustrating. I already replyed with a comment about not being able to turn the tower counterclockwise. it jus spins and doesn;t release. what now. please reply
o.k this time i tried to turn the spray tower clockwise and it just spins and doesn't unscrew?
I was told to unscrew the spray tower clockwise and remove it to get to a screw that needs to be removed in order to take off the spray arm. we are trying to get to the impeller of the pump to remove a cherry seed we thnk is stopping the water from entering the machine., but the tower just spins in place and does not unscrew. What next?
