Dear Sirs, My LG HT953TV turns itself on and off in random. PLease can you help me finding how to fix this problem? it is really disappointing to be watching a movie or listen to CD and the system keeps truning itself on and off. many thanks for you help. Kind regards, Hugo
  • Hugo Miguel Ramos Sep 05, 2010
    hi, this is home theatre no TV included the TV is samsung not LG. does your suggestion still applies?
    many thx.
    Hugo
  • David Feehan Feb 04, 2013
    Did you get this solved. I had this for 2 years. Unit has been in and out to LG and they couldn't find an issue.Its solved now by luck. The fuse went so I changed the fuse and it hasn't done it since. Could be the same for you.
  • 3,083 Answers
This isn't going to be a setting, or easy fix, but it is possible to figure it out. This is most likely a temperature problem in the power supply, and you can let the set warm up, then take electronic freeze spray, and spray the various components until the unit turns back on.
It helps to have a working knowlege of electronics, but one can focus on the voltage regulators and ICs. Be careful, since you'll have to work on the set live, and I don't recommend inexperienced persons trying it. A possible fix would be to set a small or medium fan to blow in the fin vents of the set- it might cool it enough to keep it working.
Wish I had an easier answer, but it sure sounds like a thermal problem. It's also possible that it's a cold or cracked solder joint.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 06, 2010
    President:
  • 1,961 Answers
What you are experiencing is unstable supply of voltage coming from the power supply section of your LG TV. If you can manage to open the back cover of the TV and look for the power supply board, then change all blown and bulge capacitors. (The power supply board usually came at the end of the power plug) The capacitor should be replace with exact value.
If you still have questions. Just post back.
Please do rate this answer
Thank you for using Fixya.
Alp
Posted on Sep 05, 2010
What do i do about my lg ht system ht953tv that shows protection
The unit has DC Offset, meaning a damaged amplifier. This issue will not allow the unit to turn on until the damaged is repaired.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 22, 2014 | LG Audio Players & Recorders
My lg neon turns itself off after texting
your phone has a virus and needs a hard reset available at the lg store where you bought it or any other store than handles lg.
Feb 24, 2010 | Cell Phones
My env3 always shuts off for no reason
It is a common problem with them.Every couple days,remove the battery for a few min.and let the phone reset itself.You also should shut the phone off a couple nites a week.And remember not to over charge it.It is never a good idea to leave them on the charger for more than a few hours at a time.I was having the same problem with mine,And now it seems to be fine
Oct 09, 2009 | LG enV3 VX9200 Cell Phone
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
LG KS360 phone on button not working :\
you need to master reset your phone and also update your software settings
Apr 17, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Sony FX1 water damamged
Did you find a fix for your FX-1? I think mine got wet as well.
May 01, 2008 | Sony Handycam HDR-FX1E Camcorder
Keeps turning itself off
yes it is ...what they should do if they reflash the firmware and it still does the samething what you will have to do is get them to exchange the phone for you.
Jan 13, 2008 | Sony Ericsson W850i Cellular Phone
A single vertical red line
That means the LCD panel itself (the actual glass) is broken. Don't delay, return it and get another before it's too late! The problem will most likely NOT go away, and there is no fix other than to replace the panel itself. The panel, when purchased separately, can cost more than the monitor itself.
Dec 27, 2007 | LG L1915S 19" LCD Monitor
211 people viewed this question
 Grubhead
Grubhead
