Question about Skype IM
How do you solve skype playback device problem?
    New Friend:
How to correct play back device problem on my computer for skype
Posted on Apr 27, 2014
Problem playback device skype
Reinstalling the Skype could be cure the problem.
Aug 10, 2014 | Acer TravelMate Computers & Internet
My ASUS S56C ultrabook wont let me make calls on skype. It just comes up as "Problem with playback device."
Have you tried to reboot? Camera, Mic in service? Are you using headphones? Try without. Have you updated Skype recently? If so, Remove and install older version, I have had this issue with Skype Updates, They just don't work well with some machines. Tale a look at older versions here: http://www.filehippo.com/download_skype/ Read The Comments.
Dec 25, 2012 | ASUS Computers & Internet
When i try to call someone or someone calls me on skype a yellow bar pop ups and says problem with playback device how do i fix it?
If you are using skype
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it
Jan 17, 2011 | Skype IM
I want to open skype account,what is the complete solution for this?
you download the skype client, install, add credit if you wish to phone non skype users.
You will need to go settings on skype to set your default mic and speaker devices, I use a USB skype phone.
You may need to then go to your computers audio settings and change its default playback and record devices back, mine always change to the usb phone for my computer sound.
Skype is available here http://www.skype.com/intl/en-gb/home
There are user guides available here also
Sep 10, 2010 | Computers & Internet
I am having Skype audio problems. My students could always hear loud background noises. When I checked the net for some ways to solve it, I found...
Its most likely the microphone you use. Try buying a logitech webcam instead of the one you are using. I prefer the Logitech 9000.
Oct 18, 2009 | Skype IM
Others can't hear me on skype
Open control panel.
Click on Sounds and Audio Devices.
Click on Voice.
Make sure the microphone is plugged in.
Click on test hardware.
If it works there, make a note of the default devices in Voice playback and Voice recording.
You will then have to make sure the same settings are in the Microphone and Speakers boxes in Skype.
In Skype click on tools, the audio settings.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Can't hear my sound playback on sound test with skype
After you install Skype and have it operational with you ID . Go to "TOOLS", click on "OPTIONS", nect go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correct Then "make a free test call" .Wait till the voice tells you to record. Then when finished talking waite for the test voice and the test persons voice to insue you audio transmition is work. Then go back to options and test your video.setting. Click on Video Settings and procede to set up you video camera. Also Visit this site to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jan 05, 2009 | Logitech Quickcam Chat Webcam
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Microphone doesn't work
go to the control panel, sound and devices, voice test hardware there you can check your headset is working or not if working there voice playback or voice recording both check the volume if mute then unmute it
if solve rate me
Sep 27, 2008 | Intel REALTEK nc-r150201 Network Adapter
Skype IM Logo
336 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
Lesley Cameron
Lesley Cameron
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
