Hi, My washing machine Kenmore StyleMaster 909926 could not drain today. Can you please advise what the problem is and how / if I can fix it? Thanks.
    Scholar:
  • 59 Answers
Check the drain filter and the drain pump The pump could be blocked or the hose to the pump from the bowl inside the machine might be blocked. If you can get to the pump take the inlet hose off and see if it has a stoppage. Otherise the pump might be faulty.Good luck.
www.thewashingmachineman.webs.com
Posted on Sep 05, 2010
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 90 Series washing machine Stylemaster 4217017. It quit spinning tonight. How do I fix it?
Possible that the belt or the drive or the spindle assembly is the suspect. Click this link for tips to reset: Drum Reset
Jan 19, 2013 | Kenmore Washing Machines
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Kenmore Washing Machines
Kenmore stylemaster 909964 80 series. will not agitate or spin. please help
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 11, 2010 | Kenmore Washing Machines
Washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Mar 10, 2009 | Kenmore Washing Machines
Broken kenmore washer
I have a Kenmore style master model #4217013 but it stopped spinning last night. Please let me know what to do.
Mar 27, 2008 | Washing Machines
Washing Machines Logo
207 people viewed this question
Top Washing Machines Experts
