Question about Compaq Computers & Internet
I have a full presario-Rp(d:) I did a couple of auutomatic cleanings, I have an external drive and it still prompts "getting full" It also says i need to contact the administrator to remove other programs, I thought I was the administrator.
    Genius:
  • 1,340 Answers
If you click on start,control panel,user accounts,user accounts again,it should show that you are the Admin.For now you should try a disk defragment on all drives.Did you name the external drive E: or F: or something other than the internal drive's name?If not,it may just be storing the same stuff on both drives.Click on start,in the bottom window where it says search programs and files,start to typ defragmentor and it should auto pop-up after a few letters.Click on disk defragmentor and when prompted select all.It will take a while,perhaps all day with 2 drives.In the meantime,would you tell me what Windows you have and the memory capacity of each drive?Greg
Posted on Sep 05, 2010
I want to know how to restore mr presario compaq sr1720nx back to factory settings
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows based PCs. Be sure that you want to delete everything this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer. As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot".
Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate. If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Hope this helps.
Nov 21, 2012 | HP Compaq Presario SR1720NX (EL435AA) PC...
External antenna support for Dlink 2730b.
You should be able to. Most Dlink wireless boxes use a RP-SMA (rp=reverse polarity) connector on the external antenna. So you make or buy a cable to go from the male RP-SMA on the box to whatever is on the antenna (female RP-SMA obviously if you use the same antenna).
If you are going to go to the trouble, I would suggest buying a better antenna also. A directional like the small parabolic dishes work well if getting the signal from once direction.
Jul 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
Cpu running slow, even causing audio to chatter.
Yes it may affect your speed so whenever you sit on your pc just clean temporary file
  • start
  • run
  • type %temp%
  • tap enter and delete all the files
by this the speed can be improved
May 14, 2010 | Computers & Internet
My compaq presario keeps restarting itself from when i turn it on. it never makes it past the windows xp logo. a blue screen flashes really fast and then the computer restarts itself. Then the same thing...
hi this sounds like you might have a corrupt boot system file, normally the way i have solved this is to re-install windows as a repair ( not a full install ) what i mean is start system up with windows disc in, when prompted go for install, when it gets to a page that says something like, do you want to run repair or clean install run repair, it will seem like it is installing but all its doing is repairing the corrupt file system, when it is finished your system will be as you had it before, apart from my documents, that cleans that out...hope this helps
May 10, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
Have a full presario-RP(d:) disk is getting full, wanting to know how to free up the space or clear it out, i have all ready done a disk clean up and i still havn't got enough storgage
Uninstall any programs you no longer use also why not burn any pictures or music etc you have stored on the hard drive onto a compact disc or dvd if it's capable of burning them.
Aug 04, 2009 | Compaq Computers & Internet
RP-310 Cutting
Try changing SW 3 to on for FULL CUT.
I think it may have to be in Epson mode to do this as according to the manual but try it anway and let me know if you need further help.
Mar 04, 2009 | Partner Tech RP-310 Printer
No more space in presario rp d
presario rp d is used for the operating system if you format u wont be able two use system recovery which it doesnt affect your computer if u format it bbut its all on the user ...
Feb 09, 2009 | Compaq Computers & Internet
External disk drive full when i try a operator initiated backup
Before runnning the backup please go ahead and run the check disk once..
chkdsk /f/r use this command on the command prompt
Nov 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Compaq Presario V6000 dvd rom drive disapeared.
This has happened to me since I bought the machine. You need to reinstall your DVD driver. Go to your systems window, selected devices, select drives. You should see the DVD drive (probably a Toshiba). Uninstall the drive. You will be prompted to restart the machine. When it restarts the DVD will operate normally. I use my DVD-R alot and I have to reinstall the driver every couple of weeks.
Sep 05, 2008 | Compaq Presario 12XL 104-106 Series 6X...
Computers & Internet Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
