Question about Kenmore Refrigerators
What does it mean if the doors to the refrigerator are hot where they come together when shut? It's a Kenmore Coldspot Model number 106.55642500
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.( "where the doors come together when shut" )
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Posted on Sep 05, 2010
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
Kenmore coldspot refrigerator repair
20b285e5-2f39-4d20-a743-32f4ef00196e.jpgKenmore uses a model number like this example=> 321.2468901 and can be found around the fresh food section door frame. Let me know that number so I can look over the parts so I can help you solve this, Thanks Sea Breeze
May 09, 2013 | Kenmore Refrigerators
I have a Kenmore Coldspot model 106.61282102. The drain is consistently blocking and I clean it out at least once every other week. Now the front panel by the door is overheating. Are they related? Can...
Do you mean the panel between the refrigerator an freezer. There is a heater there to keep condensation from forming.
The drain should be flushed with hot water and baking soda mixtue.
Jul 22, 2011 | Kenmore Refrigerators
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
146 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
