Question about Sears Washing Machines
Kenmore dryer model 11066662500 wont heat How do I
Kenmore dryer model 11066662500 wont heat How do I replace the heating element?
jsrock516
  • 5911 Answers
SOURCE: F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
docjohn174
  • 943 Answers
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Posted on Sep 15, 2008
  • 686 Answers
SOURCE: dryer not heating up
check your air flow coming out of dryer if it is good and stong then you should change the high limit safety thermostat and the cycling thermostat.
Posted on Apr 04, 2009
sclarke7
  • 222 Answers
SOURCE: Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Posted on Apr 07, 2009
Maytag317
  • 1136 Answers
SOURCE: No Heat on Kenmore Gas Dryer Model 417
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 18, 2009
I have a kenmore dryer model 8904 and it runs fine but it wont heat up
These are several things that can cause this, I will list them in order of "most common" to "least common."
1) Most common: The heat element has failed, they break in two pieces, and must be replaced.
2) One of the thermostats or a fuse has failed, and must be replaced. If this is the problem, you must also clean the whole inside of the machine's ductwork of lint, or having replaced the part, it will fail again.
3) A wire has burned in two, often near the heating element. Rarely, it can also be near the electrical cord in the back of the machine.
Be blessed.
Feb 12, 2014 | Kenmore Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
I have a kenmore dryer model 96585210 it wont heat up
The Heating Element went out and needs immediate attention. A simple replacing of the heating element will fix your issue. 10-15 minute job.
Apr 18, 2011 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Kenmore dryer 110-86094110 wont heat. Heating
Hi, Check all the thernostats and the thermal fuse for continuity. They should all show a closed circuit. If any of them are open, it will need replaced. It is usuallly the thermostat on the top side of the element housing.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 28, 2009 | Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
127 people viewed this question
Top Sears Washing Machines Experts
Fred Sops
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
