Question about Reebok T 1280 Treadmill
The motor belt keeps slipping. I've adjusted the running belt as instructed in the manual. Should I apply belt dressing to the motor belt and lubsicant to the running belt? Which lubricant should I use for the Reebok T 12.80?
  • 6 Answers
SOURCE: how do you adjust the belt on a reebok 500 es treadmill?
http://www.iconservice.com/reebok
Posted on Apr 18, 2009
maxtreadmill
  • 832 Answers
SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Posted on Apr 26, 2010
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok 8050es treadmill walking belt has started
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
Posted on May 06, 2010
  • 218 Answers
SOURCE: reebok irun
replace the drive belt
Posted on Aug 11, 2010
I have a Ryobi bench grinder and the grinding belt keeps slipping to one side have tightened to maximum and the belt says its for a Ryobi
it is slipping to one side because the pulley on the end is not aligned correctly
on the adjuster arm that holds the front pulley there is a lever or knob that you use to adjust alignment ( instructions in user manual) find that adjustment and slowly move it while the belt is running
you will see the belt running position change to you get it properly aligned
each belt regardless of ryobi or generic will need adjustment after fitting
Nov 27, 2016 | Bench Grinders
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
Healthrider 500sel
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
Oct 30, 2011 | Exercise & Fitness
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
My belt keep slipping. And I try tighten the ajustment bolts.
Make sure you adjust vthe motor belt first, it may be where the slipping is coming from. You should only be able to twist a properly tightened motor belt 45 degrees. After that, readjust the walk belt. If you have been tightening the walk belt trying to get the slipping out it may be too tight now. Use the instructions in your owners manual to adjust the walk belt. Also, lube under walk belt with the recommended lubrication . That will help the walk belt not too grab and take pressue off of both belts. Good luck
Mar 15, 2011 | Horizon Exercise & Fitness
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
Simpson Encore 605 - belt sometimes squeals during spin .What maintenance should I do? Spins fine - just squeals from time to time.
Many washers squeal when spin starts. A new belt usually solves it. A bit of belt dressing for car fan belts works wonders. **unplug it while you apply belt dressing!
There is usually a tension adjustment by moving the motor mount back a small amount. Don't over do the tension.
Apr 02, 2010 | Washing Machines
If I stand on the belt it stops moving
Unplug unit remove motor shroud so you can see the drive belt, plug in unit then start it you will be able to see whether the drive belt or running is actually causing the problem.If it is the running belt then turn both rear roller adjustment bolts clockwise in equal quarter turn increments until treadbelt stops slipping. NOTE: Be sure to run on treadbelt to ensure that the treadbelt does not slip while under load. Use 1/4" allen wrench
If the drive belt is slipping then to adjust the belt you must loosen the adjusting bolt on the motor frame then hold the motor by hand applied tension to belt then tight bolt you should be able to twist the drive belt no more then 45 degrees if you can repeat adjusting process.
Mar 13, 2010 | Proform 760 CrossTrainer Treadmill
Belt slipping
on the roller/brush where the belt sits if that is scarred up or grooved out that will cause the belt to slip if you can fix roller try but i suggest new roller
Dec 02, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Reebok T 1280 Treadmill Logo
258 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
