I have a samsung flat screen (not flat panel) HDTV type # CR32z30; which will automatically shut off after about an hour or so of operation, and stay off for some time. It seems to be influenced by heat or temperature.
  • 3 Answers
I would need to know the correct model number to help you.
Posted on May 12, 2008
  • ron347m Jun 26, 2011
    Check the B+ voltage, it should be 145V. If it is higher (mine was 162V) then R818 (140k) has increased in value. That resistor has 140V across it and is part of the 145V supply feedback.
    The 145V feedback is a simple divider to a TL431 and opto-coupler.
Can't get sound out of the audio output but the tv sound works fine. Samsung CR32Z30
In the initial set up procedure, there may be an option to disable internal speakers and direct audio output to an external device such as an amplifier.
Jan 27, 2015 | Samsung Televison & Video
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
My 42" Samsung Flat screen
IS HE SCREEN TOTALLY RED !! if yes check power supply all voltages if normal replace x board
Apr 26, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Can not get tv to turn on
It's normally a power failure/surge on the main board. Most common with LG tv's of this type. Samsung tv's of this type don't actually turn off, they only go on standby, which is why you can turn the Blue Eye off in the menu. One solution to try (if you haven't already), is to disconnect it from the mains (this is also the only way of actually turning the tv off), leave it for 24 hours, and try again.
Nov 28, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at...
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Nov 10, 2008 | Samsung Televison & Video
No image
See my solution and part numbers for other comment. My total cost, including free S & H was $440.
Jun 25, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HDTV 52" Flat Screen
Sound like the power supply with a bad capacitor.
Dec 13, 2007 | Samsung SP42P2S Television
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Electro Med Services...
