Question about KitchenAid Dishwashers
Dishwasher leaking at bottom of door - KitchenAid Dishwashers
  • 4,340 Answers
This area is not actually sealed, look for correct amount of correct soap and water fill limiter.
Posted on Sep 05, 2010
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Leaking bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 24, 2010 | Frigidaire PLDB998A Built-in Dishwasher
Why is my dishwasher leaking from the bottom of the door? Is it a seal???
It could be the door seal,check for damage.Check how dishwasher is loaded and make sure door is closing fully.Check bottom spray arm has not split on the outer edges.Clean all filters.
Hope this helps.
May 14, 2010 | Dishwashers
Dishwasher leaking out the bottom of the front door
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher leaks from the bottome of the door
if it leaked everytime then it would be your door gasket.but not everytime it's your door latch not engaging completely everytime.open the door and look and see if you can access the tightening screw for the door latch.probably not but look anyway.if you can then tighten the latch.
Nov 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
