There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
    Brigadier General:
  • 4,044 Answers
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Posted on Sep 05, 2010
Every time I try to print to my Dell 3110cn printer, a message pops up stating "Load Tray 1 024965 Executive" Paper tray is full and inserted correctly...what do I need to do to make it print?
I would try two steps:
1) Check the "pending documents" for your printer and make sure the printer queue is empty - delete any pending document.
2) Check the printer settings and make sure the default paper type is not set to "Executive". You may also check this in the paper properties of the document that you want to print.
Apr 29, 2014 | Dell 3110cn Laser Printer
Install printer but will not print says documents in que
hi go to printer and fax double click the printer you are using cancel all the pending prints and try to print again.if the procedure wont work delete the printer driver and turn the printer off then on and install the driver..
Aug 18, 2011 | Office Equipment & Supplies
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
I have a document in the que which I can't delete
Shutdown the PC . Then just pull the power plug from the back of the printer for 30 secs.
Afterwards turn on the printer first, then the PC. It should clear out.
Sep 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Apr 10, 2009 | Lexmark International Z611 Printer
Printer not printing model z2300 on light is flashing
replace the cartridges if the lights are continuisouly flashing. or if there is a pending document in the print que it will flash the lights.delete that pending documents.
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Documents won't delete out of que Epson CX8400
Are you using Windows XP? If you are go to Start, Control Panel, Administrative Tools, Services and stop the Print Spooler Service. This should clear the pending print jobs.
Then re-start the service.
Jun 17, 2008 | Epson CX8400 All-In-One InkJet Printer
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
145 people viewed this question
jasbo
jasbo
