The Battery has run out in our safe and we cannot open it. We do not have a key for it either, How can we get in to it?
    Brigadier General:
  • 4,044 Answers
You can try replacing the batteries and using the default code to open it. Having lost the master key that came with the safe is going to make it a problem. If it's the kind of safe I think it is the battery compartment is accessible through the bottom of the key pad.
Posted on Sep 05, 2010
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    How do I change battery in safe
    Usually there is a compartment on the inside of the door that holds the batteries.
    Jan 30, 2015 | Home Security
    Battery is removed and the keys are inside
    Is it a safe with an electronic lock? The safe usually comes with a key that you should keep outside the safe not in it exactly for this flat battery scenario that you're in. The battery box for your electric lock is usually on the inside of the safe so you need the key to open the lock. You can force it open, check this video https://www.youtube.com/watch?v=aqC9V7SDKdQ
    Jan 13, 2015 | Locks & Locksmithing
    How do I open my Sentry Safe when the batteries have gone dead?
    Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
    Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Lost keys
    A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
    Nov 28, 2012 | Sentry Fireproof Security Safe Combination
    No override key to open the safe and need to change battery
    is there a reset button in the sentry safe X055 that i could use to reset the password
    Nov 15, 2012 | Safe International Sentrysafe X055...
    I hav a amsec dl4000 safe and forgot the passcode and hav no idea where the 2 keys r. the batteries work tho, is there anyway for me to open it??
    I knew someone who had a locking mailbox like that with keys when pass is forgotten or battery runs down, they could open with key. He registered it as directions said to do so you could order new keys, the old mailbox was also lockable and since owner died he had to throw it away as couldn't prove he wasn't thief. Maybe something there helps.
    Sep 08, 2011 | Safe International Digital Electronic Safe...
    Unable to open electronic safe
    Locksmiths say this is how to install sentry safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Mar 06, 2010 | Sentry Fireproof Safe
    The number 1 button will not press
    Key override
    If your electronic lock fails or you do not have any codes
    available, you may use a key override to access this unit.
    1. Remove the battery cover, disconnect and remove the
    battery holder.
    2. Insert the skeleton key (second set of keys provided)
    into the key hole inside the opening for the battery.
    3. Turn the key to the right.
    4. Turn the four-bitted key to the right.
    5. Open the door.
    You can download the user manual here:
    http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
    Dec 24, 2008 | Sentry Fireproof Safe
    Computers & Internet Logo
    117 people viewed this question
    David Payne
    David Payne
