Question about A D S Audio Players & Recorders
Power doesn't come on, and no sound. One of the connector wires from the powered subwoofer to the crossover box pulled loose from the bottom of the subwoofer. Can I get this resoldered to the unit? I am also checking the slo-blow fuse. I am assuming I have to remove the bottom of the subwoofer to do this? If these don't solve the problem, what next?
    Guru:
  • 642 Answers
Any connections that come loose can be resoldered. It is an easy DIY fix with a soldering iron and some solder. This is what you need:
http://sub.allaboutcircuits.com/images/55007.jpg
To get at the circuitry of the sub remove the rear panel by undoing the screws around the edge. Be sure to have the unit unplugged from the wall and all in and outputs disconnected.
Posted on Sep 05, 2010
Tweeters will not work
might be a problem with the crossovers inside the speaker box.take them to a technition
Nov 10, 2013 | Definitive BP7004 Main / Stereo Speaker
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
How do i set up my subwoofer sawm40
Sounds like you have a passive subwoofer, you run speaker wire from 'front speaker receiver out' to the subwoofer, the 'subwoofer out' to your front speakers. Seem like your sub has a crossover that grabs the bass frequencies and passes off the rest to the front speakers
If you have a 'subwoofer line out' on your reciever and a 'line in' on you subwoofer then just use that single wire, this would be for a powered sub. You know that you have a powered sub if your sub has a power cord attached to it.
Jan 23, 2012 | Sony Audio Players & Recorders
Speedo meter on the fiesta 2007 drops intermittently and comes back on. radio volume drops and car loses power slightly
Sounds like your alternator is trying to die out on you. Take it to the dealer to check the voltage that it's reading whenever the cars running, and when its not. Also, check the connector wires that connect to the alternator for bad spots. Or to see if the connectors are dirty. Hope this helps, James Booth
May 17, 2011 | Ford Focus Cars & Trucks
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
Where does th JVC KS-SRA 100 power cord wire into. It says 14V DC outlet. is this the fuse box or a wire on the JVC receiver. I can get satelite reception but sound
Power cord that goes to fuse box to provide power to unit. Yellow to 14V DC and black to Ground / car body.
J-Bus connector goes to receiver to amplify sound that goes to speakers.
Hit "add a comment" for further query / info.
Thanks.
Apr 24, 2009 | Car Audio & Video
Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
A electronic subwoofer crossover
connect speaker wiring for car to speaker wire side. plug the rca's into the amp ground the ground wire. run a live from the battery to the power on the crossover and run the remote wire to the blue (iso connector) wire coming from the back of the radio
Jul 24, 2008 | Car Audio & Video
65 people viewed this question
Top A D S Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an A D S Audio Player and Recorder Expert? Answer questions, earn points and help others
