Question about Sony Handycam DCR-PC109 Mini DV Digital Camcorder
I have a problem while recording, it says check your tab
  • 76 Answers
The tab is on the back of the video tape, it keeps you from recording over recordings that you have previously made on that particular tape. I hope this helps.
Posted on Sep 06, 2010
I have a panasonic handycam. It shows an error which says Check Record Tab on startup. Because of this error i cannot use the handycam. Please suggest any solutions
The record tab is usually on the tape itself and is usually red in colour.
If you slide the tab to the open position and then reinsert the tape it should allow you to record.
Regards.
Jul 09, 2010 | Panasonic NV-GS55 Mini DV Digital...
Check rec tab
A nice easy one. Eject your tape and look for the record lock on the cassette. It's usually a small plastic red tab which you slide to one side. The record will then work.
It's put there to stop you mistakingly record over the top of something you want to keep. Just make sure it's nor something you want to keep before recording over it :-)
Apr 10, 2010 | Panasonic Palmcorder PV-DV203 Mini DV...
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
What does Check record tab mean?
the term "tab" are used for sometime for "switch" and "button". So from general information, I think the camcorder has some kind of switch malfunction. Usually record button (toggles on and off) may be the problem if all other functions in PLAY mode is working. Also you may have "protective record tap" on tape may be changed. Hope this helps. -james
Mar 27, 2009 | Panasonic Palmcorder PV-DV102 Mini DV...
Speakers
I suggest that you check and ensure that the correct playback and recording device is selected in the sound properties of your system. Please refer to the steps below as a reference.
1. Click on Start > Control Panel.
2. In Control Panel click on classic view, located at the side bar.
3. Next double click on ‘Sound’ and go to ‘Playback’ tab.
4. Please ensure that under ‘Playback’ tab; the headset is selected as default device.
5. Next go to ‘Recording’ tab and ensure that the microphone of the headset is selected as default device.
6. Now, try to take a test recording using Sound recorder.
7. Click on Start > All Programs > Accessories > Sound recorder
8. Take a test recording with Sound recording using the microphone of the webcam. Then playback the recording and check whether it was recorded clearly.
Jan 11, 2009 | Dell Inspiron B130 Notebook
Volume control on windows mixer
have you check which input the system is selected for recording it mite be site for the mic not the line in
check this in xp by going to the mixer
click options
click properties
check the box recording
now it should show the recording sliders (check marke the mark the following boxs to see the sliders)
Line in press ok
Put a check in the Linein slider and make sure it selected and turn erup
i also use wave labs and forge and quick basic test if you can record from the mic then its selected as the input
make sure other inputs are down as you will also get feedback from the builtin mic
Oct 08, 2008 | Computers & Internet
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Recording
of course, the first thing to check is the record protection tab on the cassette tape. other than that, check inside the camera to make sure a small piece of tape label or plastic isn't stuck in the mechanism, perhaps keeping the record protect sensor switch from operating.
Mar 09, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Jan 20, 2008 | Sharp Viewcam VL-AH151U Camcorder
Sony Handycam DCR-PC109 Mini DV Digital Camcorder Logo
42 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
