Question about JVC KD-G310 CD Player
JVC Cd audio player removal, which tool do i need?
Hi just wondered which tool i need to remove the above CD unit from my car, i tried the 3 prong tool but that isnt correct, its so frustratingh as no one seems to know
Hope you can help many thanks for youre time
Steve
Sorry i ment the 2 prong tool
Steve
Posted on May 12, 2008
How to get CD out of my JVC CD player kd PDR 30
It may be necessary to remove the unit and disassemble it enough to get access to the jammed CD for removal.
Jun 26, 2017 | JVC Car Audio & Video
I have a 2004 Ford Escape. I'm wondering how to remove the cd player?
  • Ford stereo head Units and CD players are some of the easiest to remove. First you need to get a set of Ford stereo/CD removal tools.
  • Basically you take them tools and stick them in the holes that are on either side of the CD player until they "click" into place.
  • The pull outward on both of the tools at the same time.
  • Now while pulling the tools outward you will pull them towards you and the CD player will pull forward.
  • Same with the head unit.
  • Unplug the connector from the CD player and that job is complete.
  • Thank you for using FixYa.
Regards, Tony
Jun 19, 2011 | Audio Players & Recorders
Cd stuck in player
sometimes a butter knife and a lot of patience works but other times i found it easier to remove the head unit and disassemble it. Its a pain but itll save the cd and your lens from any possible damage
Jan 24, 2011 | JVC KD-G110 CD Player
Tryed to load a cd and one was already in there now it want work i reset it and it still want work
Hello MikeMalcolm,
Sorry to hear about your problem! Lets see if we can help you out!
This can be a common problem with this style CD receiver. There are two different ways we can go about removing the CD(s) from the deck. The first I will explain is the most simple requiring only a few tools and about 10 minutes with hardly any effort. The second will require much more time and more advanced tools.
Method #1: Paper clip Magic
1. Most JVC CD Receivers have a very small hole next to the eject button (possible under and over a bit) Take a paper clip and bend it to the straight position and push it through the hole. This hole is designed to be a CD release mechanism. If successful the CD will eject.
Method #2: Find the eject mechanism
1. The eject mechanism is located behind the faceplate directly under the CD. You will need to trigger this lever with a toothpick or paper clip like mentioned above. Once you have this lever triggered use another toothpick or paper clip to lift the CD slightly so it can exit the CD player easier.
Method #3: Remove the Chassis ( Very Risky and Can Damage your CD Receiver and render it useless. Only attempt if you are a stereo professional.)
1. Remove the CD player from the DIN in your car. Usually requires unplugging the wire harness from the back. Also you will need to unplug the Radio wire and connector from the back. Unscrew the four screws that attach the receiver into the car frame. (Usually 4 on the very front, but differs from vehicle to vehicle.)
2. Once you have the CD player removed from the DIN slot of your car place it on a solid flat surface. Grab your sink or any other bare metal surface to discharge any static buildup you may have created while removing the unit.
3. Pry the metal tabs away from the chassis on the case of the CD player. This should allow you to open up the cage of the CD player leaving the CD mechanism exposed.
4. Eject the CD manually by either pushing the CD out or triggering the eject lever.
Also here is a link to the JVC KD Series Manual
I hope this suggestions work for you! If you have any questions you can find me on FixYa as Vexed Demon!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | JVC KD-G430 CD Player
I have removed my JVC KD-G801 from my car but realised that there is still a CD inside the unit. How do I remove it?
Hook your power wires and ground up to a cordless drill battery , 12 volt, or 14 volt. Or use jumper wires from car battery. Hit eject. You don't need all the speakers etc hooked up.
Feb 13, 2010 | JVC KD-G801 CD Player
Cd is stuck the reject botton won't work
1 Try this: While holding the SELECT button, press the ATT button for 2 secs. It will rest the player and eject the CD 2 To unlock the CD While pressing CD, press and hold 0 for more than 2 seconds. “EJECT” appears on the display, and the CD eject from the slot the slot # If above does not work you have to open the cover and remove CD manually
Nov 19, 2009 | JVC KD-S5050 CD Player
My cd player doesnt wants to get a cd...it doesnt let it in
check if unit has a reset pin switch anywhere .If not remove /unplug power from radio for a few minutes to see if it resets..try that
Aug 05, 2009 | JVC KD-G320 CD Player
JVC car stereo won't play cd
If it does it with any cd and it played before you have to clean the lense or laser. Get a cd player laser cleaner disk or cd. If you still have problems take the radio fuse off in the fuse block to restart it. Remove the fuse wait five minutes then reinstall. Also some times when you burn CDs in the wrong format the cd player will not recognize them.
May 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-G420 in 2000 Toyota Tocoma
today's in-dash cd players are a 2 part mounting system. One part is the carrier chassis that is hard mounted to the dash. Then the cd player slides into part 1 and latches. To remove player from part 1, insert 2 long and narrow metal tools along each side to un-latch the player. The tools come with a new unit. To make these, try making them out of 1/16 inch thick metal and trimming to following dimensions: 6 inches long by 1/2 inch wide and at one end, narrow down to about 1/8 inch about 1 inch from the end. deburr all edges. This 2 part system is designed for anti-theft defense.
Aug 26, 2007 | JVC KD-G420 CD Player
JVC KD-G310 CD Player Logo
145 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
